I just purchased the 500E, and I have questions:
1. Is it possible to disconnect the A/C from going off when the accelerator is floored? It's Texas here.
2. The shift linkage is gimpy trying to select D. Have to go to 3 then to D to get Drive engaged. Can the linkage be adjusted? Maybe bushings?
3. The auto stability (ASR ?) has been turned off and ASR light always comes on. The check engine is also on. Are these connected or is the CEL on for another reason?
Thank you!
Sent from my iPhone
Thank you!
Sent from my iPhone
