I have a '94 E420 and recently acquired a used rear differential that I intend to swap out with the existing one currently on my car. Originally, I had intended only to clean up the exterior, but was wondering about what other work and/or items (seals, gaskets, etc.) are worth checking over/doing before making the swap. Also, once the existing diff. is out, what other items (flex disk, subframe bushings, etc) are worth checking/replacing with the car up and diff. out?
The car has 180k miles on it and is running fine, with no obvious issues. Just replaced the shocks all around, but none of the other rear suspension rubber.
Thanks in advance for any advice you can offer.
