<threadjack>The bulletin cure? A nice along highway drive in second or third gear.
The same procedure (10 minutes at 4000rpm) works absolute wonders prior to your smog test. Since I started doing that as of last fall, I've seen the CO and NOx numbers near or at (!) zero on a three different M119 cars. Never had results that good previously.
500E: 16 HC, 0.04% CO
E500: 00 HC, 0.02% CO
S500: 13 HC, 0.00% CO
The M104 Gerrywagen is due for the sniffer this month, I'll repeat the process and see what happens.
</threadjack>
