As Gerry and 777 have done in the past, I decided to complete a top-end refresh project over the past 6 months. Last night I finally got everything hooked back up and together and sadly now have some knocking noises coming from the drivers side cylinder bank. From my ear, it sounds like an old W123 diesel clacking about, which is never a good feeling.
Here is a video of the noise:
History / testing notes:
1. Had valve covers off to replace gaskets / timing chain guides / oil separator valve.
2. Intake manifold was fully off car / new gaskets were put down. During this process engine was turned over by hand to close off valves to clean.
3. Ignition system is all new from Coils > Plugs.
4. Injectors were cleaned / fresh o-rings, etc.
5. Before initial start up - engine was cranked without injectors hooked up to build oil pressure. No noise / knocking was heard at this time.
6. Post running the engine for small amount/s of time to confirm noise, drained a small amount of oil out from pan and noticing very small amount of metal flake / particles. Distinct looking metal, but not in large quantities.
Not wanting to jump into worst case scenarios, I figured I would come here for some advice on next testing steps.
Car notes: 1992 500E / ~156k miles / Ran fine before this refresh beyond a limp home mode from what I diagnosed as the ETA failing (sent off to Don for rebuild)
UPDATE: Editing first post for historic lookup - Issue was the lifter on cylinder 7 ticket. Resolved by running car fully up to temperature + driving it around the block. Post this the lifter noise was no longer active.
