Hi.
I have a 500E 1991 witch have been checked to seep in coolant in cyl 4 so needing a headgasket job.
The question is as I can't see it from mercedes own WIS program that only shows hos to do both at the, same time.
Can only the right side be done?
Do you have to remove the intire front cover that goes around the crank or just the top front cover?
Anytip pris and cons to do this job?
Ive done several M102+103+104 count less Tines so I know my way around these very well, but the M119+120 not.
And I know a timing chain job with guides might be easily included as well.
