So, while I was in New Zealand last summer, my brother backed into my 93 400E. He popped the right headlight and corner light. I'm headed back to New Zealand again in 10 day (I'm a ski instructor and I follow winter to the southern hemisphere) and I am attempting to get ol' 400E working well again so my girlfriend will drive it to work now and again to keep it from settling into a parking spot.
When I go home to asses the damage, I found, if I turned the headlights on, the washer fluid for the headlight wiper would run non-stop. So I ordered a Euro headlight set and decided it was a good reason to change em over. I'm deleting the wipers which makes it a bit easier. So, I've got the new headlight together with new bulbs and I decided to test them before I installed them.
The right headlight low beam, fog light and turn signal are inoperable. I moved the assembly over to the left side, and it works. I moved the left assembly to the right, and it doesn't work. So I have established that the headlights them selves aren't to blame. I put the multimeter to the harness and found I'm getting 10v to one of the sockets (which belongs to what? I do not know), the other sockets are getting 2v or less. I tested the left side, 12v everywhere. I moved up to the fuses, tested #14 and #13 and I'm getting 12v.
So, sorting through what information I can find online (which is not so much), I am finding that next I should look at the control relay. part number 126 542 01 32. I don't mind replacing it, but I'd really like to know for sure that the current stops there. I cannot find a wiring diagram or pinout for this relay.
Does anyone have any experience with this. The headlights worked before my brother hit the car and I'm not sold on the accident causing the bad relay. I've worked in the industry long enough to believe it's simply coincidence, but nothing is better than a smoking gun.
Thanks in advance!
Thanks in advance!
