Since the topic of the AMG R171 SLK55 , W209 CLK 63 330mm/4 piston rear brake conversion came up again a few days or weeks ago where also a link to the 190rev board iirc was posted, I thought to give you a "how to" from my side.
Actually it's a pretty easy job in case you have already the 300mm face lift (rear) brakes on your car. If not you definitely require the heat shields off the face lift model also new rear wheel bearings and a press or the Mercedes special tools.
I bought even the heat shields for the SLK55/CLK63 and new wheel bearings but when I saw that the only (shape wise) difference between the E500 300mm heat shields and the ones from the AMG brakes is some trimmed areas (top side and caliper area) plus since my entire rear axles hasn't even been driven for 300km since the rebuild, I decided to trim the installed shields according to the measurements of the AMG units.
I taped the areas with masking tape and took a grinder with cutting disc and removed the areas which are not needed. Then put on a sanding disc to smoothen the trimmed area, finally used a file and sanding paper for the finishing. Then took black lacquer and touched up the edges of the heat shield by a brush.
The rest is straight forward, put on the disc (you have to remove a small pin on the hub which is no longer required) secure the disc with the 5mm allen key bolt, set the side brake (side brake fits 1:1 from the 124), bolt on the calipers (convert to stainless lines if wanted) put the pads in, bolt on the brake wear sensor socket (fits 1:1 too) and perform a thorough brake bleeding. Thats it. Actually I did the job at home (as you can see) and not in my garage with the jack, it's fairly easy and doesn't require much high tech (if 300mm brakes are the point to start from).
Since I m also always concerned about unsprung weight and rotating masses, I checked the weight of all items prior installation and took also the weight of the 300mm components (new disc's and pads).
AMG 330mm disk: 8.49kg
300mm disk: 7.27kg
AMG 4 piston caliper (incl pads) : 3.42kg
2 piston caliper (incl pads) : 3.64kg
Increase of rotating mass (total(left+right)) : 2.44kg
Increase of unsprung mass (per side) : 1kg
Overall this is acceptable in my opinion.
