To bad they are so rare.
Chicken or egg terry? ;D
Here some photos of the collected AMG parts to convert my car to a 6.0. I will remove the heads and replace valve stem seals all the timing chain and guides, oil pump, connecting rod/main bearings as well as the oil pan (engine came out of a W140). Since I got it together with the AMG modified transmission I will swap over the valve body to my newly overhauled one. As soon I start I will post photos here...
Only thing I m missing now is the E60 stabilizer bar and the AMG springs/shocks. Hopefully will find them sooner or later too!
To have all information suitable to the car, the new engine number and code 957 got already documented in the vehicle data card.
Also did some research with the Manufacturer and got the exact date of the engine conversion 19.07.1994
Looks nice! Any chance you could check the code numbers on the camshafts (see pics attached), and measure the cam lobes for intake & exhaust? I'm curious what you find for the lift measurements. If you could get measurements better than 0.05mm that would be great. Definitely would be nice to hear what Bernard recommends for tweaking the AMG 6L motor.
Awesome - thank you! Related question: Are the cam sprockets adjustable (slotted), or are they standard sprockets? I'm pretty sure they are standard on the .97x/.98x, but never have had my hands on a genuine AMG motor to see firsthand. Think only the tall-deck .960 had the adjustable/slotted setup.I had just remembered this but have not yet all measurements and the code numbers noted. However the intake cam measurements of my engine are:
Base circle 37.1mm
Lobe height 47.2mm
Lift = 10.1mm
Exhaust cam and both codes not checked. Will check this in about 2 weeks.
My bonnet is already pre- tensioned but at speeds over 240ish the front outer edges lift off about 1cm . That felt not so good, have to look at this again.
Nice!
Your dashboard is covered with leather, as far as i can see.
Is a handmade stuff?
Thx
Careful from that bonnet, the 124036 bonnet lock mechanism is a weak point at +270km/h.
The first owner of my Brabus 6.5 had the lock area reinforced, he also wired the blinkers after one of them flew off and scuffed the fender.
No one in this world had fun with a 124036 like he did![]()
Great car....what color?
Rouvenovich’s work as always is exquisite and impeccable. Very very very nice!
Rouvenovich = Rouven + Tovarich
A little bit of fan boy stuff here. Had ordered a few key rings for some of the cars to make grabbing the right key easier...
