SL 60 ignition module replacement with E500 unit
Dre@work
E500E Newbie
New Member
Hello guys!!!
I have an ignition module failure, one cylinder bank completely failed. Do you think it is a big problem if it is replaced with standard module off an E500? Do you think it is going to affect performance somehow?
Thanks for your thoughts
Hello guys!!!
The 6.0 engine should run normally with a 5.0L EZL. Any chance you could post a photo of the unit currently in your SL60?
BTW, welcome to the forum!
:welcome3:
Engine compartment looks really clean. Where is the EZL located on the R129? Can you post a photo (and part number) of the EZL currently in the car?
