Hello, so Ive been having problems with my car. Its never been running right since Ive owned it. It is a 1995 SL500. I have another post trying to figure out an ignition system fault code. This post is mainly about the fuel system. I did a fuel pressure test and I have an attached file showing the test sequence. On the attached file below the nominal values I have my values. First test 3.586 bar (52 psi) second test 4.068 bar (59 psi with no vacuum). So both those test pass. Third test on the bottom (fuel system internal leakage) my car fails spectacularly. It fails instantly going to 0 bar/psi fast. On that test it says “if pressure drops quickly, replace check valve in fuel pumps”. What is the check valve in the fuel pumps? My car is again a 1995 SL500. Under the car I have one fuel pump and one filter. I will attach a photo of what that looks like because I know years are different. When I turn the key on the pressure jumps up but instantly falls off almost to nothing. When I turn the car off it also then drops to nothing. I had a problem with a fuel line (pinhole leak) and replaced it when installing a new fuel filter. I should probably replace all the lines.
Main question is what is the check valve in the fuel pumps? You guys are always awsome and if you could point me in the right direction, I thank you.
