Hi everyone,
I’m in the middle of a nightmare while refreshing the engine mounts on my W124 500E. While reinstalling the engine mount bracket (arm), one of the bolts snapped off flush inside the engine block during tightening.
I’ve attached a photo of the situation. As you can see, the access is extremely restricted. There is absolutely no room to get a drill, an extractor, or a welder in there without potentially dropping or pulling the entire engine.
I am planning a full "engine out" overhaul and restoration in about 5 years. My question to the experts here:
Can I safely run the car with only 3 out of 4 bolts on that bracket for now? Does the M119 bracket have enough redundancy, or am I risking a cracked block or a catastrophic failure of the remaining bolts due to the torque of the V8?
If this is a "total no-go," are there any "voodoo" tricks to get that bolt out in such a tight space without pulling the motor?
Thanks in advance for your help!
