Hi guys
My steering box is sweaty it’s not coming from the pitman arm seal but from the top of it . I can’t see where it is leaking from . Any idea ?
You'll need to clean it all off - totally dry - to determine the leak source. Also verify if it is power steering fluid, or engine oil. A leak from the valve cover gasket can drip engine oil onto the steering box.
Ok little update on 1500 mi trip
The sls fluid went down and the only place I see a leak is on top of the steering box
Where can this be from
The front of the sls pump is dry
