I didn’t pay close attention to how the lamps work till the latest saga, so, hang in for some details. The car is a Canadian spec peasant model (1995 e320):
1. I always kept the lamp switch in the O position. When car was started, all exterior lights including low beams would come on. [But the manual says that everything should be off except when the engine is running and the gear selection is in a driving position]
2. Only had to adjust the switch when i needed the fog lights.
3. Last week, all of a sudden none of the exterior lights would come on in the O position except for the low beams. When I turn the switch to the first position on the right (called parking lamps), all exterior lights come on like in point #1 above.
So, my car is behaving like a Frankenstein. And the fact that the default didn’t work like the manual (point #1) tells me that someone dicked around with the wiring…
All fuses look good and planing to check the relays next.
Any other troubleshooting ideas?
Thx!
Thx!
