Hi all,
I just had the bulb out warning light come on, and was notified by a friendly police officer last night that my driver side "running" tail light (the one that comes on when you turn on the headlights) is out.
I changed the bulb but it didn't work. I tried taking the bulb from the passenger side assembly and plugging it in the drivers side assembly, that didn't work either. I tried wrapping the bulb in aluminum foil in case it was a ground contact issue, that didn't help either. I unhooked and re-hooked the wiring assembly and tried jiggling all the parts, but that didn't help either.
I have a voltmeter coming tomorrow so will check if there is any current, but I suspect there is not.
I searched the forums, sorry if I missed a troubleshooting guide for this, but didn't find anything. Any suggestions? Hopefully I don't have to replace the entire panel.
Also- I replaced the outer tail light reflectors and lenses a few months ago with the smoke/red ones rather than the stock amber corners. Looks great but I just learned that there is no cut out for the side-facing corner light in the reflector housing. Has anyone just cut out or carved out a notch for that light so that the side corner is illuminated?
Thanks for the help!
