Does anyone know of an extraction tool for a stripped oxygen sensor? I am working on an Audi and the passenger bank rear O2 sensor has likely never been replaced. Being a Michigan car its whole life, the sensor has seemingly decided to weld itself to the exhaust manifold. I snapped a 3/8" drive extension and broke a 1/2" drive socket trying to get it off. With a stronger-walled socket, I managed to strip the outside of the sensor.
Before I take a drill to this I thought I'd see if anyone has seen anything on the market for a situation like this. I have bold extractors, but they are for much smaller bolts -- nothing in the 22mm range.
The good part is I have a clear shot to the sensor from above but I'd rather not drill and risk damaging the threads if I can avoid it. I'd probably drill it out to the point that I can hammer a triple-square or Torx into the center and see if I can break it loose from there. Thanks in advance.
