| | 722.3 Transmission Seal Part Numbers |
013-997-09-46 | 1 | Seal ring, 722.3 input shaft / tq converter |
016-997-14-48 | 1 | Seal ring, 722.3 pump to front cover (big O-ring, ~144mm) |
126-272-00-92 | 1 | Seal ring, 722.3 reverse piston "boot" (inside, small) |
126-272-01-92 | 1 | Seal ring, 722.3 reverse piston "boot" (outside, large) |
126-272-09-55 | 2 | Seal ring, 722.3 front cover shaft (Teflon, 2 required?) |
126-271-12-80 | 1 | Gasket, 722.3 front cover (flat, paper) |
140-277-00-80 | 1 | Gasket, 722.3 secondary pump delete cover (late trannies or rebuilds) |
016-997-39-48 | 1 | Seal ring, 722.3 governor cover |
016-997-04-48 | 1 | Seal ring, 722.3 kickdown / Bowden cable (O-ring) |
140-277-01-51 | 1 | Seal ring, 722.3 reaction valve B1 - Spacer ring (Plastic cup, not Teflon) |
005-997-80-48 | 1 | Seal ring, 722.3 reaction valve B1 (seal 1, inner) |
016-997-34-48 | 1 | Seal ring, 722.3 reaction valve B1 (seal 2) |
016-997-35-48 | 2 | Seal ring, 722.3 reaction valve B1 (seal 3, tiny, OL switch) |
005-997-86-48 | 1 | Seal ring, 722.3 brake band B1 cover |
005-997-70-48 | 1 | Seal ring, 722.3 brake band B2 cover (O-ring, red) |
140-277-04-55 | 1 | Seal ring, 722.3 brake band B2 piston (Teflon?) |
126-277-09-55 | 1 | Seal ring, 722.3 brake band B2 piston inner (?) |
006-997-73-47 | 1 | Seal ring, 722.3 brake band B2 piston inner (?) |
016-997-29-48 | 1 | Seal ring, 722.3 dipstick |
014-997-11-48 | 1 | Seal ring, 722.3 vacuum modulator |
012-997-87-47 | 1 | Seal ring, 722.3 output shaft seal |
115-304-01-60 | 1 | Seal ring, 722.3 kickdown solenoid - Aluminum ring to trans |
008-997-30-48 | 1 | Seal ring, 722.3 kickdown solenoid - Medium size (middle) |
008-997-31-48 | 1 | Seal ring, 722.3 kickdown solenoid - Large size (outer end) |
001-997-35-48 | 1 | Seal ring, 722.3 kickdown solenoid - Small size (inner end) |
016-997-34-48 | 1 | Seal ring, 722.3 inductive speed sensor & plastic cup (same p/n as reaction valve B1) |
126-271-04-82 | 1 | Plastic cup, 722.3 - For inductive speed sensor |
006-997-01-47 | 1 | Seal, 722.X selector shaft |
016-997-32-48 | 1 | Seal ring, 722.3 secondary pump to trans (O-ring) |
016-997-37-48 | 1 | Seal ring, 722.3 secondary pump small cover (O-ring) - May not be used? |
126-277-08-55 | 1 | Seal ring, 722.3 secondary pump (Teflon ring, large) |
913016-006000 | 1 | 722.3 secondary pump 10mm sealing nut |
220-271-00-98 | 1 | 722.X pan magnet |
013-997-23-48 | 1 | Seal ring, 722.3 vacuum modulator plastic cap (on late style modulator only) |
126-987-07-45 | 1 | Plastic cap, 722.3 vacuum modulator (late style only) |
