I need a recommendation on whether or not I should have the transmission serviced on my 1992 400E. It has over 189K miles on it. I called a local service center that specializes in German imports and they warned that I not get it done. Their justification is that the discs in the transmission have worn off the grit on the discs by this time. He said the grit is still in the fluid and that is why the transmission is still working, but if you change the fluid, you remove the grit from the transmission and it will start to malfunction. Since I have no experience with working on transmissions, let alone Merc transmissions, I'm asking for some advice from the guys in this forum who might have some experience in this area. Thanks...
What Steve said. It mirrors my experience exactly. Thanks, Steve! You saved me from having to write it.
