For some reason if I use a quote I have to space down at the least 3 lines or better lines or it will all run together here even though before I post the thread or comment everything looks as it should. This happens ONLY on this forum and on no other forum I post to.
Also spell check here is big time screwy as in obviously missed words will not show as misspelled unless I manually right click spell check which will be checked then uncheck it and then rerun it manually. Again this is ONLY on this particular forum and no where I post.
Something in the script here is just not playing nice with what I am running and it's driving me NUTS!!!!
This forum software does not have integrated spell-check capabilities. Only one's computer has spell-checking capability. So, any spell-check related problems would be with your computer/browser, and not this forum code.
500Eboard management and administration uses and tests this forum on Windows, Linux and Macintosh computers (not to mention iPad, iPhone and Android mobile devices) on a daily basis, with the Firefox, Chrome, Safari, Internet Explorer, and Opera browsers on all of the previously mentioned platforms, and have never had any sort of spell-check issue.
As to your spacing issue - it is difficult to discern what you are talking about, so perhaps a screen capture detailing the issue would be helpful to illustrate the issue you are having.
In quoting your post in this post, we immediately started typing this reply directly after the end of your quoted text (literally, the next character). There were no spacing issues or anything requiring extra returns. You can see what we mean in the attached screen shot, with regard to typing immediately after the end of the quoted text, and as you read this reply you can see that the spacing is 100% correct.
While we are not technical support experts, both of the above issues would lead us to believe that the issue lies with your computer, and not the forum code. About 90% of the time in the past, when our members have experienced errors, it has been as a result of issues on their end, not with bugs or problems in the forum code.
We strongly recommend using a modern browser, such as Firefox, Google Chrome or Opera to access this site. If you are using Internet Explorer, which is a rather "long in the tooth" browser, it has some incompatibilities with WWW and HTML standards that often cause problems.
Usually the forum software is very well tested before it is released and this site's software is upgraded. In the case of the vBulletin 4.X software that this forum is using, the software is very mature code (8-9 years old) and is actually nearing the end of active development by the company who makes it. Most all bugs have been fixed long ago.
Thank you,
500Eboard Administration
