US Motor Works Fan Clutch
Black 034
Has anyone used the US Motor Works Fan Clutch 22323 on a 400/500E. Supposedly US manufactured or at minimum assembled. Also I believe they make it for Autozone with a limited life time warranty.
BF
Never heard of it. Looks like every other cheap offshore viscous fan clutch (ACM, Vemo, Hamburgler Technic, etc).
I call 100% BS on the claim it has anything to do with USA besides "US" in the name, and being sold here.
The PDF is vague. It does not say that any products are made in USA and also does not say they don't manufacture outside of USA and/or Mexico.
It just shows their HQ, distribution, and "performance division" are located in USA and that there is a manufacturing facility in Mexico.
See if you can find any photograph of their fan clutch and/or fan clutch package that shows a COO.
I have ordered one and will advise. I don't see much difference between Sachs, Febi, 4 Season, Hayden, Myle,Duralast,etc. All made over seas just $100 more in cost between some of them. I guess just keep and eye on it for bearing noise and wobble. I'm hoping Mexico better than China.
Sachs (now Horton) is the OEM clutch which is a completely different design compared to all aftermarket clutches. These have been NLA for several years now.
Otherwise you are correct - Febi, 4 Season, Hayden, Meyle, Duralast, Vemo, ACM, all are half the size and look nearly identical.
Remember you must also buy a shorter center bolt (M10 x 50) if replacing an OE clutch with aftermarket.
:banana2:
Two questions how much effort to turn fan on cold engine at 80F ambient and how long a bolt for aftermarket clutch?
The fan will move with little effort when the engine is off. The only valid test is the "roar test" as discussed in some of the other fan clutch threads.
Bolt size is mentioned in my previous post.
Could you test a viscous fan clutch by using a heat gun to heat the bi-metalic strip monitoring with a temp gun and see if it becomes harder to spin?
Nope. The OE viscous fan clutch requires extremely fine calibration. There's no way to correlate air temp with coolant temp to know what air temp should begin to engage the clutch. This is why the PWM electric fans are vastly superior... they can be programmed to run based on coolant temp.
Thanks for being the guinea pig and reporting your results when you get fan clutch!
BTW --- I found this picture of a USMW water pump box on a Corvette forum --- this seems in contrast to the "Made in Mexico / USA" inferences that are peppered about in references in post 3 and 6 .... unfortunately. ☹️. Real curious to see what you get @Black 034 .
Well I got my US Motor Works / Mao Zedong fan clutch so now going back to them. I need a decent fan clutch but doesn't appear to be any available. My car was running hot 105 C in traffic 85 degree ambient with plus 60-70 humidity. I had one bad auxillary fan that has been replaced and now it is staying under 100, but only when fans kick on high off coolant sensor. Any suggestions
Try the Borg Warner (Febi) fan clutch?
As of 2016, the ACM was a repackaged Borg Warner.
As of 2025, with ACM gone, I just confirmed that the Febi clutch is a repackaged Borg Warner that is made in China: ACM fan clutch NLA ? | Heating and Cooling (Interior HVAC systems)
BTW did you happen to get any pictures of the US MW fan clutch?
I would try this clutch if I wasn't afraid of failure taking out Radiator, Fan (NLA) and hoses/lines. I don't mind if it only last 5 years or so not hard to change. Also picture of OTC Fan Clutch kit for Mercs and BMW
Thanks! Honestly to me the USMW China clutch looks inferior to the Borg Warner / Febi China clutch. Compare the cleanliness of the attachment points of the bimetallic strip, and well as the uniformity/non uniformity of the casting. BW China clutch pictured below (from @tomer)
Yes. I put in an ACM made in China in 2016 which was packaged in a Borg Warner box. It operates a little differently than the Sachs Horton clutch though - more noise, but perhaps more cooling. Also unknown if high RPM deactivation is at a higher RPM than OE. Do a search —- hours of good reading on the ACM / Febi / BW Shenglong on the forum all documented!
