Hi there. My body has atypical dimensions, I have a long torso but fairly short legs for my height (6'1") and my pelvis / hips are fairly wide.
I find bottom cushions on w124 seats to be a bit too narrow between the outer bolstering and metal spring rods that support the outer bolstering. One hip is often fatigued after an intermediate length drive from sitting up on the bolstering which slightly crooks my lower back (my hips do not sit level between the bolstering).
I noticed this issue with my 2014 E550 I had as well.
I have thought I could make a wider foam pad to place on the seat to widen the seating area but my head would touch the roof in a w124. Would you recommend modifications to the lower seat foam or would the seat springs need modification as well?
Thoughts appreciated.
