Hi Everyone!
Not sure if this is the place for this thread (redirect me if I'm wrong!).
On opening the trunk on my E500, I was somewhat concerned to see that the "well" on the left hand-side of the boot was almost 1/4 full of water! I normally keep a bag of tools, a can of spare fuel plus other "clutter" in this well, and not having the need to use any of these items recently, I'm not sure how long the water had been there. There doesn't appear to be any drain in this well, so any water ingress remains there.
Having removed all the trunk lining on that side of the boot, I discovered a "pressure-release" grill on the side panel of the boot. This pressure release grill has rubber flaps on the outside which are supposed to open when the boot is physically closed to allow air pressure out, but which are supposed to remain closed when any water is played on the outside to avoid any ingress of water.
However, when I played water down the outside of that side of the car, I discovered that water was leaking not only through the edges of the grill, but also around the rubber flaps which are meant to remain closed when water passes over them on the outside! I think over time the rubber has lost its "memory" to remain tightly shut.
I have now removed and resealed the grill (it has a rubber seal, which was "shot"), but this is only a temporary repair pending the arrival of a new grill, which hopefully will not leak water through the rubber flaps.
Not too desperate an item, but one which could have consequences if this "well" is not checked at frequent intervals to ensure there is no pool of water.
The pressure-release grill is only on the left-rear of the boot. There isn't one on the side of the battery, so hopefully no issues with the battery box becoming water logged!
P.S. On reflection, maybe this well should have a simple drain hole, and mine has become blocked with crud and unidentifiable over the years?
