I'll make multiple runs with mine when cleaning all the droppings from the pine trees. Those things seem to always be dropping something on the ground...
When I moved into this home in 1978 there was a 40’ pine tree in a planter next to the driveway and about 20’ from the garage door. It was a magnificent looking tree as far as trees go. Sure it dropped pine needles that had to be cleaned up weekly but not to much of a problem UNTIL about a year later when we had a freek thunderstorm! When I went out the front door after the storm passed I was shocked to see about 1/2 of my yard and part of my roof completely brown covered in pine needles about an inch deep. That was enough and the demise of the tree
Our Flagstaff house is in one of the largest contiguous Ponderosa pine forests in North America. I couldn't tell you how many trees we have on the 1/2 acre property, suffice to say it's easily 20-30. They're all 40'-60' tall, if not taller, and constantly drop/drip stuff. If it's not needles (primarily in the spring) it's pieces of lower branches, which die off naturally and then rot and fall to the ground. They also drip pine sap constantly, although the rate changes with the season. Right now it's small, fine droplets, where in the spring as they're producing "offspring" it's heavier. You definitely don't want to park your car outside unless it's covered. And they also drop pine cones and the little pods from when they produce pollen.When I moved into this home in 1978 there was a 40’ pine tree in a planter next to the driveway and about 20’ from the garage door. It was a magnificent looking tree as far as trees go. Sure it dropped pine needles that had to be cleaned up weekly but not to much of a problem UNTIL about a year later when we had a freek thunderstorm! When I went out the front door after the storm passed I was shocked to see about 1/2 of my yard and part of my roof completely brown covered in pine needles about an inch deep. That was enough and the demise of the tree
I spent the following week cutting down the mess making tree. I actually climbed up as high as I could and tied a rope even higher. With my 10 year old son pulling on the rope from far away I topped about 20’ with it falling towards the street. I was very nervous about the the bottom of the cut slipping back and knocking me out of the tree. Anyway, after that it took the rest of the week to cut it down to the stump. Since my yard is practically beach sand I dug out the stump down about 4’ I cut it off with a chainsaw.
I finally cut it up into fire wood and stacked it behind my toolshed. About a year later we had our first and last wood fire in the fireplace. It was a PITA to clean out the ashes. So I took the rest of the firewood out to a construction site I was working on and dumped it. Glad to see it gone. Others picked it up and took it home.
Anyway, that was my first and last one tree.
I’m not a “tree hugger”
lol
100% Esco! I've owned a lot of different ones over the years, but I treated myself to a pair of Esco stands a few years ago. I got both the flat tops and bought a second set of "saddle" type U shaped tops. So one pair, and I can switch the type of top. I would and do trust my life with them.Anyone have a preferred Jackstand model? I'm seeing a lot of good reviews on these Esco ones and I love the flat tops vs the pinch weld style. Height is 'only' 21.5" but that should be enough for most jobs I do.
Amazon.com: Esco 10498 Jack Stands, 3 Ton Capacity, Pair of 2 Stands (Pack of 2), Silver : Automotive
Buy Esco 10498 Jack Stands, 3 Ton Capacity, Pair of 2 Stands (Pack of 2), Silver: Jack Stands - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Harbor Freight now has a knock off of the Knipex Raptor Smooth Jawed Gripping Wrench, for about 1/2 the price of a Knipex.It's not in my tool box yet, but I just flew with a GE mechanic who had this set of Knipex pliers in his toolbox. Anyone know where I can buy one? Is MAC Tools the only distributor? After all, yesterday was payday.
Home page
[EDIT] Just ordered:
https://www.ebay.com/itm/KNIPEX-Hea...-Wrench-Nickel-Plating-86-03-180/282872476194
Admin edit: Also offered here:
Knipex 86 03 180 SBA $61.94 Pliers Wrench, 7 1/4 In | Zoro.com
https://www.amazon.com/Knipex-8603180-7-Inch-Pliers-Wrench/dp/B000X4KP1C
Smaller version too:
Knipex 86 03 150 $58.77 6" Mini Pliers Wrench, Plastic Grip | Zoro.com
PLYWOOD
Yes I know plywood is so mundane. However I decided recently that I had enough of cluttering up my drawers with power tools and wanted to hang my power tools somewhere. I also didn't want to clutter up my wall space with hanging my power tools (wall space is at a premium) so I decided to slap a piece of plywood on the side of my cheapo Costco CSPS Tool Chest and hang my power tools from the plywood.
Conveniently, my tools chest had a handle on the side of it that was secured by 6x 10mm M1.0 bolts. I took off the handle and used longer bolts to secure the plywood, then hung my tools from the plywood. Problem solved! PS Bonus - $5 Craigslist score on the CRAFTSMAN vice (circa 1970s?) I picked up.
Out here in the west we use regular ply, not sanded birch ply for sheathing, but c'mon, I don't want my garage to look totally jury-rigged-grade ---- I'm gonna use kinda-of-nice plywood in my garage!!!They use sanded Birch ply for sheathing out there don't they? Probably why housing costs so much.
@Jlaa - where did you get the brackets from for hanging your tools?PLYWOOD
There are a gazillion of them on Amazon and they are all very similar. This is the one I used on the top (with the captive shelf). Note that it was only $22 a few days ago (now it is in the 30s....) but look around on Amazon and I am sure you can find an identical one for cheaper.
There are certainly times where I could use something like that but it probably wouldn't get used that often.
I can sort of understand this with modern trucks, as they're so high off the ground you probably can't reach much just standing next to or in front of them.
After spending an hour or two in moderate discomfort sprawled over the top of the engine with my face near the back of the M119 intake manifold, I was wishing for something similar to this. Not sure how much it would improve comfort, but might be worth a shot. Maybe I'll wait for a sale and give it a whirl.I can sort of understand this with modern trucks, as they're so high off the ground you probably can't reach much just standing next to or in front of them.
You could just build a scaffold out of lumber...make it larger and pad it and it would be way more comfortable. You could even take naps on itAfter spending an hour or two in moderate discomfort sprawled over the top of the engine with my face near the back of the M119 intake manifold, I was wishing for something similar to this. Not sure how much it would improve comfort, but might be worth a shot. Maybe I'll wait for a sale and give it a whirl.
What, no Whitworth wrenches?I looked for a long time and really liked the holder design for these Facom spanners so went for the 12 peice set.
Facom tools are made in France as far as I am aware and these feel high quality.
Apparently Milwaukee is doing the 100% right thing. Owning up to the problem and offering to replace all the new models with new guns designed the same as the old "version A" guns
I, too, am very intrigued! I looked up AE and I found this:@Stegel, do you have a link to your GYS induction heater?
Very cool I knew of those machines but have never used one. This would fall into the bracket of "not used enough to justify the cost" for me personally. But great idea and the ability to heat just a bolt red hot but no naked flames or damage to surrounding area a huge advantage.This is the one I have:
GYS 068643 Powerdeduction 10R (UK) Induction Machine
GYS 068643 Powerdeduction 10R (UK) Induction Machine The Powerduction 10R is designed to heat, unlock to enable removal of mechanical parts such as worn nuts and bolts in seconds. It is especially recommended in the automotive, agricultural, maintenance awww.campbellmillertools.co.uk
I can see this being very helpful working on older cars, especially ones that have been in conditions that promote rust.
Remember the good old days when there were only cis-fasteners?I have dealt with (and continue to almost daily) soooo many fasteners which no longer identify as bolts I have 100% success rate ...
Those are the ones I use, after many years with a cheap set. I used them on my recent rear SLS sphere replacement on my E500. Very happy with them. I would recommend them.Anyone have a preferred Jackstand model? I'm seeing a lot of good reviews on these Esco ones and I love the flat tops vs the pinch weld style. Height is 'only' 21.5" but that should be enough for most jobs I do.
That looks like a killer deal. Why do I have to be married to the M18 FUEL platform?If you're in the Makita 18V ecosystem and need to grab a bunch of batteries, a really good deal deal just popped up at Ace Tool.
For $199 you get four (4) 5.0 LXT batteries as part of a big-boy (2x18v) circular saw kit. Includes a double charger and a bag.
They'll have some deals as the holidays approach, I'm sure. I hope. I could use some more (larger) batteries.That looks like a killer deal. Why do I have to be married to the M18 FUEL platform?
I have the opposite problem, after a couple of previous deals that came with extra batteries. I could use a cordless 7.25" saw but don't really need more batteries, although I guess I could resell extras on Craigslist. Then again, for the price, it might be hard to beat the Makita saw deal with FUEL equivalents.They'll have some deals as the holidays approach, I'm sure. I hope. I could use some more (larger) batteries.![]()
FYI - Ace Tool charges shipping, ~$40 to my address.If you're in the Makita 18V ecosystem and need to grab a bunch of batteries, a really good deal deal just popped up at Ace Tool.
Currently, (2) 5.0 batteries are $212 on AMZN and $229 at the Home Despot.
I have the 6-1/2" M18 Milwaukee circular saw. I have continued to be amazed at how well it works and the limited battery consumption. I built a set of steps for an exterior deck back in September, and I was able to use it for nearly the full day doing cutoffs and such without changing a battery. It plowed through 2x6 and 4x4 cedar like it was buttah.I have a 6-1/2" 18v Makita circular saw. LOVE that damn thing. Only time I've reached for a larger or corded saw is for track sawing. The 7-1/4 unit in that deal is a pretty serious machine. Maybe not quite for production framing, but pretty damn close.
Four batteries for $200 is absolutely killer. I'm stocked full of batteries these days, else I'd be grabbing that deal.
I think I'm going to ask Santa to bring me a small top handle Makita battery chainsaw. I've got the larger 2X18 saw, and it's been really handy. My small Stihl has always been a shoulder-buster. No matter who has tried to service it.
Harbor Fright's latest email claims their Daytona clone 'beats' Esco:100% Esco! I've owned a lot of different ones over the years, but I treated myself to a pair of Esco stands a few years ago. I got both the flat tops and bought a second set of "saddle" type U shaped tops. So one pair, and I can switch the type of top. I would and do trust my life with them.
I have had this balljoint splitter for years and at the weekend it bent trying to split a joint on my w140
That tool is scrap now and I have a balljoint still stuck. So I ordered a hydraulic type ball joint splitter with 8 tonne force. Will try it as soon as it arrives in the hope it will be up to the task!
Joe, I can see why you need that tool. The amount of rust you deal with is unbelievable.
When the other balljoint tool bent I knew to find a better solution and stop before damaging the good track rod end and potentially having to upset the steering geometry etc unnecessarily.
The 8 tonne hydraulic balljoint separator was the highest spec which would fit a car I could find and it arrived today.
Easy to use and first try the stuck joint popped free. Just a case of the right tool for the job!
View attachment 156546View attachment 156547
The old tool is bent and will be binned but the strength difference is easy to see between the two. S classes do tend to have fairly large ball joints so this new tool will get good use.
