Windscreen washer fluid nozzle upgrade?
e500.org
Hello all
Apologies if this is the wrong section however I have always thought the w124 windscreen nozzle spray is a little lame/trickles and prefer the pressure and the spray pattern of the later MBs.
I have of course cleared it out however all the w124s I have seen have the same pressure/spray pattern.
Has anyone retrofitted the nozzles from a newer MB or other cars to a w124?
Cheers
Generally if the system is in good nick, it should spray with some good authority. It's probably a matter of replacing the nozzles and pumps for proper operation.
Speedy's 140 retrofit is interesting -- but what I see as the main problem is that each of those 140 pumps lists at $190....discounted to around $140-145 apiece.
That's some pretty spendy squirting, as compared to the "pedestrian" pumps (A2028690021), which list out at $52 apiece, discounted to around $40 each.
Massive help guys thanks. I guess no nozzles however drop in that can change the spray pattern. I'm going to give this Febi part a try.
Don't forget the check valves. Those can partially clog- been a problem for me at times. Cheap to replace, but cleanable too.
Thought I recall that the W201 three-nozzle squirters would fit on the 124 hood, but I don't know for sure, and also don't know if that will perform how you'd like...
Dave:
The three hole squirters are from the early W201 84/85 with that have the central hole in the hood and right side parking non articulating wiper arm. Once Mercedes went to the later left side parking articulating wiper arm they also went with dual squirters, but they only had 2 holes vs three.
Jeff
There's probably debris in your nozzles. Find the thinnest copper wiring you can, and try to clear them out. That's what my guys end up doing. Some distilled vinegar in the reservoir won't hurt, if the car sits for extended periods. I'm in FL, and mold in the reservoir is a constant problem.
GL, hope this helps.
Can someone with EPC please tell me the correct PN for the windshield wiper nozzles? on the Revolution website it says the correct PNs are 124-860-16-47-7126 and 124-860-15-47-7126 and both are NLA, so I’m hoping that they might have been substituted by another PN that is still available. Thanks!
The imperfect (but workable) solution is to use W202 washer nozzles:
A2028601147 (left)
A2028601247 (right)
IIRC they fit the hood cutouts the same as the W124 nozzles, but the electrical connector (pin bushing housing) is slightly different. You may need to swap the connector from the W124 nozzle.
