Has anyone had any personal experience with the Big Brake Kits from YSR out of Texas?
yellowspeedracingusa.com
Yellow Speed Racing Front 6 Piston Ultra Big Brake Kit - Mercedes E Cl
Yellow Speed Racing’s Ultra Series Big Brake Kit is designed for road and track use. This big brake kit features optimum braking performance, attractive looks, easy installation and a cost-effective price. Factory brakes are designed primarily for daily driving on most applications. If you have...
- Forged billet aluminum split design calipers with anti-rust coating, featuring vented aluminum pistons standard for improved heat transfer resistance
- Two-piece drilled, slotted, or drilled & slotted rotors with lightweight aluminum center bells. Rigid steel center bells are equipped for the rear rotors integrated with inner drums
- High Performance OEM+, Street, Sport or Competition Brake Pads
- High quality stainless steel braided Teflon brake lines included with every kit
- CNC machined steel caliper mounting brackets for bolt-on caliper installation
- 304mm x 26mm | (11.97" x 1.02")
- 330mm x 28mm | (12.99" x 1.09")
- 330mm x 32mm | (12.99" x 1.26")
- 345mm x 32mm | (13.58" x 1.26")
- 356mm x 32mm | (14.02" x 1.26")
- 365mm x 32mm | (14.37" x 1.26")
