Hi,
Hope y'all can help- Recently when I start my 500E, the ASR/ABS pump (photo below) begins making loud and strange noises. It sounds like a loud slurping as if there is air in the pipes mixed with the brake fluid. It does this for usually less than 1 minute and then the pump completely shuts off as if it has some kind of safety cut off.
When the pump shuts off Santa visits my dash. A green, red and yellowy/orange ABS light come on on my instrument cluster- usually all together. The photo below shows the green light. Ignore the brake warning on the left, it was doing its job fine.
Note: previous owner changed the instrument cluster. This one has no light with ASR written on it.
But i have concluded that:
- Green (2nd from right) means ASR. It has no writing or symbol- just a blank rectangle. If it comes on i can get unlimited wheel spin. It used to always be joined by red but less so these days.
- Red (3rd from right says SRS on it it so i assume its airbags) Since I've owned the car, Red has never come on alone- only come on WITH green.
- Yellow/Orange (4th from right) is the ABS light i believe. It says ABS on it.
I figure I'll probably have to pull the pump out? Let me know your thoughts or experience.
Cheers.
The pump ^
Cheers.
The pump ^
