Looks like we got another knowledgeble person with a beautiful car !
Love you color it is just astonishing especially with Evo !
You have a right attitude to 036 replacing everything it needs and does not need just to make it look better !
Diagnostic software is reporting the year of the software in the E-GAS module. It cannot tell when the ETA was manufactured. The date code on the label is what you need to check, and yep, yours is a newer one so you can relax.I also checked my ETA...and it seems that it is made in 2005....?but how come on my diagnostic it says "software 1992.....?can someone please verify what year my ETA is?
No, it's not written in stone. A newer ETA can still cause problems if the internal potentiometers are worn. This is relatively rare, but not unheard of. Difficult to diagnose without swapping in another ETA!
Brakes will swap over (need the front LCA's too), but otherwise there isn't much useful from the R129. The differential is not the same either, it's a reinforced housing and there isn't any advantage to it (if it will fit at all, which I'm not sure about). Transmission bellhousing is different so you can't use the tranny either. But, it would be a nice donor in case you wanted to build a 7.4L M120 for your 500E...can i ask you a question gsxr... do you know of any parts from w129 600sl that fits the 92 500e ?
there is a 1994 model 600sl available for parts not far from where i live...
i think about brakes....suspension stuff...differential...rear beam...and so on...not electrical as that is self explenatory![]()
is the rear beam the same you know?Brakes will swap over (need the front LCA's too), but otherwise there isn't much useful from the R129. The differential is not the same either, it's a reinforced housing and there isn't any advantage to it (if it will fit at all, which I'm not sure about). Transmission bellhousing is different so you can't use the tranny either. But, it would be a nice donor in case you wanted to build a 7.4L M120 for your 500E...
Pretty sure the rear subframe and axles are different. The 5 links should be the same but you probably wouldn't want used ones. Rear sway bar is probably narrower.is the rear beam the same you know?
 If it's really, where did you get it? I've tried to search mats for long time and dealer says that they are NLA.
A bit OT..
In that picture which is taken from the trunk of your car seems that you have unopened set of velour floor mats, or am I seeing correct? Do you really have new velour floor mat kit?If it's really, where did you get it? I've tried to search mats for long time and dealer says that they are NLA.
Really nice car you have, hope you get her fixed!
 yes, I'm sorry, Stefan.yes, I'm sorry, Stefan.
Love your video and your joy! Nice work. I was LOL at the "it f@c^&$g starts!"...
thank you so much for your kind words man.Glad you like the videos..and especially one with a 500e brought back to life
heheh i was abit LOL myself at that point.hehe.![]()
Very impressive detective work.
Glad you were able to get to the bottom of your problem.
Good diagnosis! And funny video, can understand how it feels to find such an fault...
Always love a success story. Watched the videos and felt a bit of me was on the roller coaster with you. Very happy you found the issue. Beautiful car too!
Congratulations!
I love your attention to detail.... defenately OCD level![]()
