I've spent probably 40 hours in the past week, doing final research on server setup and configuration for the new web site. Totally picked this project back up with gusto, and made my final decisions on what we're going to do moving forward.
I also did one final test install of the latest version of XenForo, which is version 2.0.4. Added Tapatalk for XenForo and other extensions, as well, as part of the test installation procedure. A lot of command-line work (server root access, etc.) to upgrade the database version, php language version, implement a SSL (for security) certificate, and otherwise lay the groundwork for the new install. I also purchased a second "skin" which will provide an alternative "look and feel" for the new XenForo installation, so you'll be able to choose between two different looks once the new forum is activated.
Below you can see the standard XenForo interace, and the new (green) one that I purchased.
I'll be entering into a new server contract as of Friday, March 30th. At that time, a new (temporary) domain will be activated for the forum, something along the lines of 500Eboard.net. This will be the URL for the new forum (
https://www.500eboard.net/forums). The data import and migration will commence at this time. The current forum will be frozen (not deleted), and once everything is up and running, eventually the existing domain (500eboard.com) will be migrated over and will become the proper domain for the new forum. I don't expect this domain migration will happen for a week or three, until I know that everything is up, running and configured properly.
During this transition time, when the existing vBulletin forum is frozen, I will redirect the 500Eboard.com domain to the new forum, so you shouldn't see anything differently in your bookmarks (i.e. the old domain will point to the 500eboard.net forum/web site automatically). The new forum should open up and be ready for business once the data is imported, things are configured properly, and things are generally working correctly.
As I found with the transition from phpBB (remember 500Espot.com back in 2012?), there is likely going to be a period of some days and weeks when the forum settings and configurations need to be tweaked, so that they are equivalent to the settings that we have in vBulletin. Because all of your passwords are encrypted, and I do not have access to them, you will probably have to log into the newly transitioned forum with your password (and if you forgot it, I will be able to send you a password reset link). This will be a one-time deal with the password, if it comes up.
The final test install of the XenForo 2.0.4 forum is up and live at
https://www.500ecstasy.org/forums if you want to see it. This test install will be removed in the future, but I'll keep it alive probably until sometime in April when I cancel the contract for this server that it is using. I have already cancelled the three other test server contracts that I have been using for the past few months to test server configurations, etc.
The new server contract that I have settled on will provide much more overhead and capacity, so that the site can handle more simultaneous users. It will also use a dual-processor configuration, and will have up to 9 GB of memory (the current server has up to 2 GB of memory). This will give a lot more overhead for future site growth. We will also have unlimited storage capacity for images (currently totaling more than 23 GB of images and growing).
This project has been long in the making, and it's time that we get it done once and for all. This should position us well for the next 10 years of the forum's life and growth, and on a new forum software platform that is being regularly updated and actively developed by the XenForo folks. vBulletin has been totally stagnant for the past 4-5 years, and even vBulletin says that it is at the end of its life.
In the past few weeks, the XenForo folks have significantly updated and upgraded the importation capabilities over what they used to be. This should make the migration go much easier, as the capabilities when I did this same full "test" migration a couple of years ago were much more crude and a manual process, and I had to do some custom coding (working with the XenForo developers directly) in the php language to accommodate the test imports of the forum. It's much smoother, better and easier now, thanks to the efforts of the XenForo folks.
In any case, just wanted to let folks know of the decisions I've made, what will be happening, and what to expect. The configuration process that will happen in the post-transition time frame is going to be the most grueling thing, because it's going to require many hours of fine tweaking and attention paid on very small, minute things.
