I believe the original amps have built-in equalization and are designed for drivers with a specific impedance. If you change the drivers with the stock amps, the result is NOT always optimal. Remember that just because it sounds
different, doesn't mean it sounds
better. The Morel driver you linked to just might fit, it would be an interesting experiment if someone wants to plunk down ~$350 to try them out.
I have the full Jehnert system in two different 124's and it sounds very, very good. But it's not cheap for a complete conversion. I'd rather have dual 6.5" drivers than a single 6" but that's just me...
Yep the original amp probebly has some sort of time adjustment built in it, and when you start messing with different speakers/setups you are making a mess of it.
In my car the jehnert setup sounded underpowered. You didnt need go to high before you got clipping in the speakers.
If you only have the front dash speaker setup and no elements in the door the jehnert would be an upgrade. If you have door speakers i would just update the dash speakers if i could not find a speaker for the door. But you would need a 2ohm speaker setup. Blam Relax series are 2ohm and would be perfect with the original amp.
Original speakers are 2ohm. Same are the jehnert. Most after marked typs are 4ohm, and will be a bit harder to drive for the original amp. Many guys update to Rainbows and they are 4ohm so the original amp will only have half power when they are in use. So to get the most out of them you need an aftermarket amp.
And since the amp is made for 2ohm load i dont know how good it will be with a 4ohm load. Should not be a problem as they often has the biggest problems to be stable when you go down in ohm load.
So its not so easy to upgrade these cars "correct" on the sound side.
i saw your setup, i thought the mounting depth was about 2in
I have never had a original frontdoor cover with speakers off on a w124 car so i cant help you there. I just went of the measurements gxsr gave just to show that there are speakers out there that might fit.
I paid around 250$ for each of my custom made panels. And i guess that might be able to have it done cheaper in the US.
Right now im doing a budget upgrade in my daily car. An s124 (230te)
Fronts Focal 130AS
Rear doors Focal 100AC
Headunit Alpine UTE-93dab
Amp might be Alpine KTP-445A (only thing i have not bought yet so it might change)
Fronts need some mods to get in. I might do a thread on the build when i start on this.
In time i want to do subs in the rear floor tray. One or two 8 inch subs. The car needs to be a user/work car so i cant have a big box in the trunk. And i want to keep the spear wheel so i dont have to many options.
