I have a problem that I cannot solve... I can't get both front speakers to play... So weird... Here are the details of my setup:
Front Rainbows DLX 4.7, rear Morel Ultra 5.2 Mk. II, amp is D class Focal 4.320. Signal for front speakers goes through factory wires bypassing fader and through HF. HF hijacks front speakers only during incoming call. Rear speakers are wired directly to amp. Amplifier is set up to clone signal from front channel input to all 4 channels output, in other words one pair of L+R signal is amplified and played through 4 speakers. When I connect everything and play music I can hear all but front left speaker. Rears always play fine. Now what I've done so far to troubleshoot:
First thought - something with the wires. I swapped out front L with R wires - music plays in L speaker, not in R. OK, so wires are fine
Second thought - I screwed up input/output settings in amp. I toggled all switches, set it up zillion times - no joy.
Third - well, I got bad amp straight out of the box. I sent it to Focal repair center under warranty. They called after few days and said that the amp is perfectly fine, no matter how hard they try to fail it... Anyway, they resoldered few joints etc. and sent it back to me.
I put it back in place, reconnected all wires and problem is still there...
Next I tried other signal source - Technics CD player. No difference, still L front channel has no sound.
Next I started to fiddle with wires. And here comes first surprise. If I disconnect ANY of the front speakers - both are mute. So if I disconnect L that doesn't play anyway - R stops to play. WTF? To force L to play I have to connect it to R output and L to R, otherwise it won't play. I really can't wrap my head around it...
I followed this path and instead of Rainbows connected OE speakers - they play fine... both channels... WTF?
To make it even more weird if Rainbows are connected directly to Becker radio they play fine, both L and R...
Does it sound familiar to anybody? I really run out of ideas...
I need to dig out the connector I made under the fader and check it out.
Everything works as designed now.
