Low fuel pressure, or high exhaust backpressure, WILL NOT trigger any codes.
The car is still at the shop, but they found one fault. The oxygen sensor was broken (not defective, broken!). I have no idea as to how the LH-system reacts to that, but you people might know?
Best acceleration will be starting in 1st gear. 0-100kph in 8 seconds with wheelspin isn't bad, although it should be closer to 6 seconds with minimal wheelspin (see video below).Today I got the car back. As already written, the oxygen sensor (lambda/O2-sensor) has been replaced. With a lot of wheel spin, the car now did 0-100 at 8,3 seconds, from previously 10,2-10,5.
I started the measurement in first gear, maybe I would get better results starting off in second. Not sure.
Are your spark plugs non-resistorHowever, idle is still not the best. It's better, but not the best. The engine seems to miss here and there at idle.
Should I fork out for a new MAF, or could it be something else? The engine does run better, mind you.
The EPC typically shows 3 different part numbers, for Bosch, Beru, and Champion. At any given time only 1 of the 3 may be available. They are all equivalent.The dealer sometimes is not sure cause there is lots of numbers in EPC as per chassis for spark plugs.
Those are the right ones, Bosch F8DC4 with MB star, made in Germany. Those are also NLA now, replaced by the Beru version (unless your dealer happens to have any of the Bosch left on the shelf).For my '92 500E they gave me these Bosch plugs with the MB star.
So I pulled fault codes, since I bought one of those breakout boxes from eBay.
Pin 7: code 14 (what is that????)
Pin 19: couldn't read anything here, didn't even get one blink. Bad connection?
I know the ETA has been replaced at some stage, because it's date stamped 02M06.
Any thoughts?
It is inside the throttle body .Okay. S29/3 will refer to this.
http://www.500eboard.com/forums/showthread.php?t=1438
Is there a procedure to adjust the linkage before I order the switch?
oh yeees...thankx.i got it mixed upS29/3 is located inside the car near the accelerator pedal.
Switches inside the ETA / throttle body are designated MXX/Y, for example M16/1.
More on S29/3 located here: http://www.500eboard.com/forums/showthread.php?t=742
Hmmm... that isn't right. Next step is to check for error codes (DTC's) on the E-GAS module, preferably with a digital scanner. And, check the throttle valve angle via digital scanner too.Yes. That I know - mine however opens to about the same with ignition on as with ignition off. Maybe (but just maybe) a tad more with ignition on.
The ETA butterfly will only open about halfway with the engine / ignition off. With the key on to position 2 (all lights on instrument cluster), if you press the accelerator pedal to the floor, the ETA butterfly will open slightly more, but still not open all the way unless the engine is running. It's a drive-by-wire system that needs the electronics energized to function.
Also, the butterfly does not open to full vertical (90°). Max opening is 80-something degrees. This can also be viewed in the live data stream from the LH module via SDS / HHT-Win.
Yes, from memory, the throttle only opens to 80-something percent. I think it's a design limit of the ETA. Drive the car at full throttle while a passenger views live data on throttle angle, and it will max out 8x%. This is very different from the C63 (M156), which was electronically de-tuned by reducing throttle opening to like 60%. Which is why the C63 "tunes" have such large power gains, they just allow it to open to max possible, as with the E63. Meanwhile, the "tunes" for the E63 barely do anything despite the crazy claims by most tuners.Dave, is this happening in driving condition too? Not full opening of throttle plate? Too long ago I have played around with the sd on the lh 500... Cause the C63 w204 was also detuned in that way from factory. The throttle did not open 100% iirc
I'd recommend the Star SDS C3 (or C4), which will do everything possible on the E500E, and also work with most all other MB models. HFM Scan does have limited capability on LH systems, click here for more info - probably need to buy some adapters, and it will only get LH data.At the moment I haven't got access to a digital scanner (a friend has HFM-scan, will that do?), what scanner can you recommend?
OK - that's the correct module, just checking! Still need to pull codes and see if there are any errors stored.My E-GAS module has the following number: 124 545 4432. If you scroll a bit up there's a picture of all the modules in the car![]()
Yes. When in limp mode, the ASR light should illuminate. Make sure the bulb is good, it should light up when you turn the key to position 2, before starting the engine.In WIS there is something called "mechanical limp home" mentioned, where you get 2/3 power available. Will ASR light up due to so-called mechanical limp home?
Usually, with a defective E-GAS module, you would be in limp mode at all times, and cruise control would not work.If I have a defective module (e-gas etc) - how will that affect the ETA? Will it work at all?
Yes, sort of, maybe. If the blink code shows 1 blink (no faults) there shouldn't be any codes displayed with the Star system (SDS) either. However it would be good to double-check. For the E-GAS module specifically, the SDS will show more accurate codes than the blinker box. Click here for details, see the attached files in that thread.Can Star read fault codes not available with the manual blinking system?
