The ETA butterfly will only open about halfway with the engine / ignition off. With the key on to position 2 (all lights on instrument cluster), if you press the accelerator pedal to the floor, the ETA butterfly will open slightly more, but still not open all the way unless the engine is running. It's a drive-by-wire system that needs the electronics energized to function.
Also, the butterfly does not open to full vertical (90°). Max opening is 80-something degrees. This can also be viewed in the live data stream from the LH module via SDS / HHT-Win.
