Your caps look ok, and it will be hard to condemn them until you replace the defective wires.Thanks for the part#, looks like I will have to order some...Or some aftermarket ones. Any good aftermarket ones, if I dont have to spend $400 I would rather not...
Beru should be fine. The lengths may differ slightly from stock, and the wires are not labled with cylinder numbers, so it usually takes some trial & error to get the proper wires to each cylinder. Might take an hour or two. No Zip-ties should be required, the wire routing is stamped in the bottom of the X-shaped tray. Excess length should be looped at either end so that it will not interfere with the plastic covers fully seating. See thread linked below; post 38, 48, and 64:Thx! Will Beru be ok, will it fit if its shorter??
Whaaa? Which vendor said 003-159-68-03 are not available? I just bought some a few weeks ago. The OE Bosch 003-159-67-03 are NLA from Mercedes, those #67 Bosch plugs were superceded to #68 which are made by Beru. You can still get aftermarket Bosch F8DC4 though. Just avoid the FR8DC resistor types.I got another ETA to try and spark plugs, not 003 159 68 03 since I got the email back they are not available. I got Bosch ones.
I am curious what brand of wires are currently installed, and if they are the early type (plug boot with rubber upper half and 90° wire ) or late (plug boot with plastic upper half, usually orange color). Check the brand name on the plug boots, wire, and cap boots. There may be a mix of brands.I will get wires too and see what happens after I replace all 3 things.
Don't get the wires mixed up, but if you do, most likely you'll get a quite unpleasant misfire and very rough running. If the existing wires are routed properly you can change 1 at a time and select the closest length; but since the current wires are already aftermarket, it's hard to say if the last mechanic did it right or not.Ok hopefully I wont have any problems figuring out wiring, can I really mess it up if, for example, I put wire from plug 1 to plug 2? I will go ahead and order it those Beru wires you sent (https://www.partsgeek.com/catalog/1992/mercedes/500e/engine_electrical/spark_plug_wire_set.html) .
BS. The plugs are available. If you only ordered plugs and nothing else (or, a few other small/cheap parts) they were probably blowing you off as they would lose money shipping that order free. Especially if they didn't have any in stock, which is unlikely, but possible. EDIT: MBoemparts shipped the plugs after all, despite the email stating otherwise - see post #116 below.mboemparts sent me an email they they are unavailable. So I got aftermarket Bosch F8DC4.
Bremi boots does not necessarily mean a Bremi-branded wire set. Check the plug boots too, and the wires themselves. I'm not a big fan of Bremi as they are not OEM for any Mercedes ignition components.My current wires are "Bremi 13222", it says on distributor cap boots. Distributor caps are Bosch. Pretty interested in seeing what spark plugs I have in there.
I've seen this too. From what I can tell, there are only a couple of mfr's that produce the boots and wires; some third parties then mix & match brands when building wire sets. I don't like the Bremi as they don't use the crimped wire ends with threaded fittings. From memory, I believe the Karlyn boots also cannot have the wires unscrewed like Bosch or Beru.I replaced the spark plugs today and when I pulled the old ones out they looked pretty bad plus they were the wrong ones, Bosch FR8DC resistor ones!
Also, GSXR you were right, wires were Karlyn at the spark plug boot side and Bremi at the distributor side, how come? How does that happen?
If your idle is fixed, that would be fabulous, but I have a bad feeling there will be no change in idle RPM.Now waiting on wires and ETA to see what happens, I am secretly hoping that my idle will get fixed with new wires and fresh, correct, spark plugs.
Yep, that is normal. IIRC each cap sends 2 wires to one bank, and 2 wires to the other. Make sure to reference the thread mentioned in post #109 above, you should be able to get your wires routed as neatly as shown in the photos with the red wires. Note that Glen's engine shows the late style plug boots, and my photos sh ow the early style. The routing is slightly different for each under the plastic cover over the plugs. The routing is identical in the X-tray and at the caps.I noticed that some spark plug wires go to the same side distributor cap and some dont, is that normal?
Oh WEIRD! I wonder what happened. There shouldn't be a big difference, I'd leave the Bosch Russia plugs in there for now. Keep the new OE Beru for your next plug change in 25-30kmi.Something strange happened. After mboemparts told me spark plugs 003 159 68 03 are unavailable, I just got them in the mail today...Not sure how does that happen. My main dilemma now is if I should put those in or keep the aftermarket ones, is there really a big difference. I like the ones I got today,they have nice MB logo and from Germany. Other ones are from Russia.
Correct.Tonight I got to work on changing the wires for a little bit...The post you sent was very useful.
Just to confirm,its a silly question but... as long as cylinder #/ spark plug wire goes to corresponding distributor cap #/ connection I will be fine, It doesnt matter which wire itself is as long as it fits?
It might get worse when you get to the 7th and 8th wires. You may even need to go back and swap out some you had already installed. BTW, can you post a photo of the wire set you got? Maybe the package with 1 loose wire if they're not all installed yet?After my 5th wire the lengths are not matching that closely anymore. But I will continue tomorrow.
That reminds me - where the 2 coil wires exit the plastic cover above the power steering pulley, make sure they are tied up and routed such that it's impossible for them to move out of position, and rub against the pulley edge. The plastic housings which bolt to the head, and the covers which go over the top, both often have broken tabs so things won't snap into place properly. If they are busted, you can still buy new ones from MB. Last I checked it was ~$75 for all four of them. Since your car is low miles, maybe the originals are still serviceable.Also, the furthest right coil wire was chopped in 3 places since it was going under the distributor plastic cover. That's probably the one shorting out.
That is BIZARRE. I've never seen Beru boots with clip-on connections!! Must be a cost-reduction thing; the older Beru sets all had threaded connections as seen in the other thread.Unfortunately wires did not work out very well. Car is hesitating slightly and one popped off when I cranked the car...Connection seems to be pretty weak.
View attachment 72387 View attachment 72386
The red wires for sale in the other thread require you to buy all the boots separately, which is not a big deal, just expensive.It would look nice to put the red wires on, it would spice it up a little. I will think about it, thx for the suggestion!
Glad you got that sorted. You tried multiple ETA's, correct? Did you only have 1 defective, or more than 1?But just to "summarize" it so far...My surging idle was because of a bad ETA. Once I got a good ETA, surge stopped but the idle was high because my ETA linkage wasnt connected correctly on the back side, where the firewall is.
That may be related to the wires, or it could be something different... you'll need to get the wires sorted first. I think you could reconnect the new Beru wires, reduce the slack at the coil boots, and make sure everything is nice & snug... then chase down the choking problem. A different set of new wires isn't likely to fix this.Now I have a weird stutter when idling and if I rev the engine and RPMS start going down it kind of chokes/stutters but it stops and goes back to barely noticeable stutter at idle. I think that's the wires or maybe car needs to adjust or re learn or something,...I might try to take it for a short drive around the block before I change the wires again.
Hello Guest !
