I need some advice. I have a 93 500E and I replaced the fuel pumps, filter, and the relay  (used relay) back in June because the car wasn't starting after being stored for 4 years. I solved the fuel problem and since then, I've been restoring the car.
Today when I tried to start the car after restoring all the injectors and replacing the lower engine harness, the engine would crack but not fire. I checked the fuel rail by the intake manifold and there wasn't any fuel pressure at all. I don't hear any sound coming from the pumps when I put the car in ignition.
However, I realized that every time I disconnect and connect again the battery the fuel pumps work only for the first time I put it in ignition and sometimes the engine starts but it stalls immediately. If I try again and put the key in ignition, the fuel pumps won't work. I have to go back to disconnect and connect the battery to get the fuel pumps to work for the first time I put the car in ignition. I don't hear a clicking sound coming from the relay and I know the fuel pumps work because I can hear them every time I put the car ignition for the first time after disconnecting and connecting the battery.
Since the relay I got back in June was used, I was thinking that maybe this could be the problem... but what do you all think? Is there anything else I should check?
