Glen said:Congrats on the new toy
Is that an A8 in the background?
bing said:oh...the 500E badge on the trunk lid looks out of position?! thought i'd mention it as you don't want people saying you've been rear-ended and that it's a new lid. personally i prefer debadged but if u want to keep it on there are measurements on this link from gsxr :
http://w124-zone.com/downloads/MB CD/ ... 88-505.pdf
This car is for sale now, from a dealer in Great Neck, NY (near NYC):
Welcome aboard! Glad you were able to rescue it and drive it. What have you done to it since you got it? What maintenance items does it need?
Maybe the PO (@Swordfish) can chime in from his end as to what happened some years back.
Sure seems like a ton of work for an impound carWow... that's full of rare parts! Nice find. Impound auction!!! 5.0L engines are cheap now, drop one in and you'll have a fun rocket.
I'm assuming it's heat warped), but first, if anyone can give me suggestions on repairing that cold slip in the transmission I'd be grateful. After about 300 feet of driving it will shift and seems to function normally, it only happens when it's cold and right about when it needs to do the 1-2 shift.
Thanks for reading and I appreciate the warm welcome!!
Sure seems like a ton of work for an impound carIt's very balanced and yes, more HP would be the ticket if I could source the 5.0. I seem to recall reading where this car did have the 5.0 dropped in when it was converted and the only thing they didn't swap in the drivetrain was the diff? 2.82? I'm probably "wishing" that it had the swap already done though hahahah
I know Mike "Swordfish" well. I'll let him know there is discussion again on his old mule.
I have a picture from a long time ago of it next to my 500E. A nice tribute car for sure and I always loved the white tan color combo.
The owner who did the swap is/was a doctor and seems he spared no expense in building it; albeit with some missing or incorrect parts. From what I remember Mike needed to find the correct rocker cladding under the doors to visually finish it off. An yes, the rear bumper cover was warped back when he got it.
No ASR !
I think you are right! I found an old email from 2011 discussing dyno runs, and I think the car DOES have the 5.0L engine.I seem to recall reading where this car did have the 5.0 dropped in when it was converted and the only thing they didn't swap in the drivetrain was the diff? 2.82? I'm probably "wishing" that it had the swap already done though hahahah
I remember reading something about it but didn't actually know how it "reacted" for lack of a better word. Out of curiosity how can I defeat it?Just a thought but are you aware these cars have cold upshift delay?
It is a system whereby the first few upshifts when setting off with a cold engine hang on or are delayed to increase engine rpm and heat the cats faster.
It is a strange sensation which I did not like in my 500E. I treat cold engines with care so it was cringe worthy to have the car trying to hold onto like 3 - 3.5k rpm or whatever it was before it would upshift. Hence I disabled that "feature"
It may not be what you are experiencing but worth pointing out just in case
I just need to start a new OWNER thread?@SchmutzigEier -- you should start your own OWNER thread for the car under your ownership. We can transfer your posts from here over to that new thread, if you'd like.
I remembered the car had already had the swap as well but It's been a good long time.I think you are right! I found an old email from 2011 discussing dyno runs, and I think the car DOES have the 5.0L engine.
Not sure about the gearing, but that's easy to figure out... just tell us what the engine RPM is in 4th gear at 60mph.
That's crazy you found that threadI haven't found the posts I think may be this car from BW, but found this from MBWorld from much earlier than I thought.. 2005
This may be the same car.. just not sure
400E converted to 500E - MBWorld.org Forums
E-Class (W124) - 400E converted to 500E - Hello everyone Im new to this forum. Im not a Mercedes owner, but I have been hired to sell a E400/E500 1993 Mercedes. This car belongs to a terminally ill friend of mine. This car was his baby. He has converted a lot of the origianl car E400 to a E500...mbworld.org
If this is the same car, this MBworld thread says $8,700 for a used 500 engine, another $4,500 to rebuild it, then $1,800 to install.
That's $15K into the engine alone, if it's all true...
The posts I remember from BW were probably around 2010-11 with different pictures, and then it was on Autotrader at a used car dealership in the NY city area later on if memory is working properly.... But it's a long time ago...
I'm betting mine is on the drivers side rear. I didn't see a stamp plate that big on the front of the intake.When I purchased Ms Bornite from Dubai, I sent the owner these marked up picks to show him where to look, he found them instantly, and they matched the data sheet. You may need to get a rag and clean off the ledge, there is room for your index finger with a rag wrapped around it...
See attached
Hard as heck to see but I have a partial of 9741 2002684 (I think)If so... then it's a pretty early build engine (1991-92 vintage). Use solvent, rags, and a wire brush on that area up front first.
Photo of the location on the rear of the block:
So, it IS a 5.0L?Sounds like 119974-12-002664. I'm not finding a motor with -684 as the last digits. Donor with engine #2664 would have been WDBEA36E3NB691106, decommissioned circa 1999 with 124kmi on the clock.
@gerryvz, you may want to update your DB with this info... see attached.
Yes, 119974 = 5.0L engine. You could also verify the engine block casting number (near driver engine mount bracket) which is even more definite proof vs the serial stamping.So, it IS a 5.0L?
