Calm down guys, I'm not saying that the M119 is a bad engine, if it was I wouldn't own 4 of them and I wouldn't be here. I am saying though that a later model low deck, shorter connecting rod, thinner bearing, plastic oil tubed, open deck M119 is not as stout as an earlier model tall deck, longer connecting rod, wider bearing, aluminum oil tube, closed deck M119 is. I think we can all at least agree on that right?
And I still maintain that the M113 is weaker still.
As far as the M116 vs M117 vs. M119 thing goes, I AM TALKING ABOUT THE BLOCKS HERE.
I still maintain that the low deck M119 block is more of an offshoot of the aluminum M116's block while the tall deck M119 block is more of an offshoot of the aluminum M117's block. They are all related. They all even have the same exact bore spacing at 4.43". (Sorry, I don't have the metric dimension. Using the .0394 conversion gives us a ballpark 112.44 mm though.) The M117 and tall deck M119 both have a 245.45 mm deck height while the low deck M119 deck height is only 229.00 mm. I don't have the M116's deck height but I'm sure that someone here does (several folks here probably do) and when they post it we will see that it is also 229.00 mm! The 154.50 mm connecting rod length is shared between the M117 and tall deck M119 too and I suspect that we will find that the low deck M119's 149.00 connecting rod length is shared with the M116 as well. And it's no coincidence that the 4.2 M116 and 4.2 M119 have the EXACT SAME bore AND stroke.
Another thing that I would like to know is what did the Euro market 91 500Es have in them? The tall deck 5.0 or the low deck 5.0? We already know that they were the first M119s to get the LH injection system but were they also the first to get the low deck block? Or is there such a thing as a one year only tall deck LH equipped M119?
Again, I never said that the M116 and M117 are the same. Quite the contrary in fact. My original post on this topic bemoaned the fact that the low deck M119 block is based on the less desirable M116 block, making it clear that it is less desirable than the M117 based tall deck M119 block. I am simply saying that the M116 and M117 are RELATED in much the same way the Mopar "B" eng (350/361/383/400) is related to the Mopar "RB" eng (383/413/426W/426H/440 [yes, there were both tall and short deck 383s]).
Speaking of Mopar, in the late 60s they were developing a new engine known internally as the "Ball Stud Hemi". This new engine was to have all of it's displacements built off of the "B" block with the "RB" block being eliminated because it is more cost effective to build all of your engines using as much shared tooling as possible. While the whole engine program was killed due to other looming, more pressing issues, Other OEMs have streamlined their engine lines in a similar fashion. The Ford 351 M is an example. It is simply a 400 block based 351 Cleveland that allowed Ford to use one block for two different displacement engines instead of using two entirely different blocks to build two different displacement engines. No doubt MB was trying to do the same thing when they put both the 4.2 M119 and 5.0 M119 onto the same low deck block instead of keeping the 5.0 M119 on it's own taller deck block.
This brings us to where we can address Mike's post about "MB had reasons for what they did". Yeah, increasingly, it was MONEY and PROFITS. Increasingly, that is WHY MB did what it did and does what it does and how their motivations were already changing and how it was already showing when the low deck M119 came out. They had gone from building world beaters being their priority to increased profits being their priority. If you read the first paragraph in this post again you can see how the content was already being removed from our engines. Then, when it still wasn't enough for them, they brought out the even lower content M113. Jurgen Schremp was and is an evil man! He very nearly destroyed MB!
Regards, Eric
Regards, Eric
