E420 ASR Accumulator / booster
EPC shows p/n 000-430-10-94 would be correct for the W124 with ASR.
000-430-05-94 should also work, it was replaced by 000-430-10-94 on the 129. Check the part number on your existing one too.
OMG you as always The Best!!! God Bless you! Really! Thank you for your patience and big help! I will able to see mine tomorrow because its in mechanic shop. I think 99% i will go with that from 129, because price is good..
Note that the ASR pressure accumulator is barely visible in the above photo... it's the small round can, not the large rectangular one.
It has a gas-filled chamber similar to the rear SLS spheres. Pressure is from the ASR/ABS unit. It's sort of a holding tank for fluid & pressure, hence the name "accumulator"... might be more details in the FSM descriptions of the ASR system.
