Following up on my Top-End Rebuild thread, I have driven the car around 1,700 miles since completing the job last September-ish.
I have only had one problem that I've noted since I completed the job -- the A/C compressor through the fall/winter/spring has been sort of hesitant to come on. It comes on either after I drive the car a little bit, or I "shock" the A/C into running by pressing the HI fan setting + Max A/C. Then it will come on, and it works just fine after it does.
I checked the A/C refrigerant & system pressure last year, and it was just fine on both the high and low sides, so I know it was not a leak / lack of refrigerant causing the system to not generate enough pressure to activate the compressor. The only thing I could think of was that I somehow disturbed the compressor or the lines going to it during my top-end work, perhaps by hosing down the area with brake cleaner or somehow being over-zealous when I was removing and installing the tandem pump. Note that I did not disturb the A/C compressor itself, or the lines (other than perhaps slightly moving them when accessing the tandem pump and lines going to it).
I had a clue today -- I checked all of the codes on the car's systems, and everything came up negative (the DI and EA-CC-ISC systems had old codes from before the top-end job, which I think I deleted all of) except the BM (Base Module) system, which threw a Code 6 and a Code 7. These correspond to the A/C compressor clutch somehow being stuck, and code 7 is the poly belt (serpentine belt) slipping. So this is a clue that perhaps I got some oil or other slippery stuff on the A/C compressor belt pulley, which perhaps is causing it to slip (or caused it to slip) and throw the codes.
I also noted that the last time I drove the car, very recently, and in warmer ambient temperatures (high 80s), that the A/C system went on right away and acted normally.
So I am going to see if I can't remove the serpentine belt and really clean off the A/C compressor pulley, in case there is any residual oil or grease on the pulley, and see if that solves the problem once and for all. It also may just be that time and engine bay heat from driving the 1,700 miles may have baked or dried up any slippery stuff on the pulley so that it is working correctly.
I will also check the fuses in the BM, and the BM itself, as I have 4-5 spare units. I am wondering if the speed sensor on the back of the compressor, or the compressor wiring, somehow got damaged or moved when I was working on things down there last year.
Anyhow, it was REALLY nice to have exactly ZERO codes thrown, with the exception of these two A/C compressor related codes. Especially after driving so many miles. That means that everything is operating 100% as it should !!!!
