My 92 500E w 240k mi has a whine or 'whomping' from the rear end of the car in operation that I've tried as best I can to capture in the attached two videos during my commute this AM. The longer one is on the highway from 60-80 MPH; it's a bit hard to hear the noise but it's there if you listen for it, along w my description of when I'm on and off load. The shorter one is driving around a parking lot from stop, where the 'whirring' that comes on once I'm moving is pretty obvious. I'm having a hard time trying to decide if it's the center support bearing (first link), or the rear diff (second link). I'm going to have the car up on a lift on Thursday night; I'd like to finally install my cat back exhaust and new hangars, but I might hold off if the support bearing or some other part of the driveshaft looks iffy. The fact that it seems to be present on and off load pushes me a bit in the center support bearing direction, but the noise' frequency and the cars service history makes me think it's more likely to be diff related. It had diff fluid done at 205k mi when the PO complained about noise; a shop changed the fluid but noted metal flakes and wear in the diff. I'm going to pull the diff cover off at some point here, but might wait until the weekend - I can only keep it up on a lift for a few hours on Thursday night, which I don't think would leave me enough time to close it and for a sealant to cure altho maybe some 90 min Right Stuff would work.
Noise at highway speed
Noise at low speed - in and around a parking lot
Will document my findings here; hoping I don't need to replace the diff as the noise is pretty annoying to me and detracts from the experience of the car. At the very least, maybe some fresh redline 75W90 will help but I'm not super optimistic so looking for some 2.82 or 2.65s...
HELP! Mystery chirping/squeaking noise | Troubleshooting and Diagnostics
My 500E has developed a mystery noise that two mechanics and an exhaust shop have been unable to identify (and they are getting annoyed by the fact that I'm not letting this drop). Here are the symptoms: 1) When the car is rolling, there's a noise I can best describe as the kind of high-pitch...
www.500eboard.co
Rear end whine | Transmission and Driveline
Not my favorite choice of German whines. Car has 240,000 miles. Fresh gear lube didn't seem to make a diff(erence). Should I learn to live with it or what?
www.500eboard.co
