I'm interested in trying Redline 10W50 10W50 Motor Oil is there a way of finding out the zddp levels for this particular oil of theirs?
D
D
Exactly! I've sent then an inquiry yesterday, hope to hear from them. If the numbers are where they should be, I could use it SL500 and S2, so I can buy it in bulk with free shipping. And "10" factor is very user friendly in my winter weather, so I don't have to change oil for the winter just to drive the car.
What's interesting is they don't list the Zinc or Phosphorus for the regular 10w50, only for the power sports version. I don't know how different they are.
Only way to find out is to ask their tech department, or find a VOA posted on BITOG, or use it and see what appears in the UOA. My guess is both will be in the 1000-1200 range.I'm interested in trying Redline 10W50 10W50 Motor Oil is there a way of finding out the zddp levels for this particular oil of theirs?
Dave,Only way to find out is to ask their tech department, or find a VOA posted on BITOG, or use it and see what appears in the UOA. My guess is both will be in the 1000-1200 range.
Is there a reason you need 10W-50 specifically? In general you want to keep the spread between numbers smaller, as that typically means it has less VI's.
Awesome. Dave Granquist has been at Redline forever! (At least 2 decades....). He is a gem. A few years ago, he last calculated this for me:Dave,
Your point is very valid indeed, but for me, for simplicity sake basically. The w202, w211 and my Volvo all in agreement for 5w40, works great for all weather, all temps. R129 loves the 50 weight, but does not like 15-20 starting point in the very cold winter days, but does well with 10. Considering that it gets about 5k miles per year, I really don't want to change oils in it just for the weather, one for the summer, one for the winter, just want to drive it.
At the same time, S2, Porsche's recommendation for oil, particularly for 944/968 cars is that very 10w50, so I can use it in both cars, buy it in bulk with free shipping and use year around in S2 and SL, this 10w50 seem like the "sweet range" for me for the weather/miles
BTW, the, redline responded, and as you said, spot on with those numbers
D
Do you have a link? I can't find Castrol Edge 5w-50 on their website. Only 5w40.Autozone has half off (that's right, 50% off) Castrol Edge Full Synthetic 5w50 TODAY ONLY. Stock up! Online only.
They run that 5w50 special often… it’s an odd spec that people aren’t looking for… I’ll keep an eye out… I learned about yesterday’s sale from the E46M guys because of the 10w60.@maw1124 Appreciate the pointers, apparently, daily deals,…
Yep, I put it in my super duty 7.3 with 346,000 miles on it. It seems to like it just fine. I would not use it on my OM648 E320CDI because zinc and cats don't get along.Any try Costco’s Kirkland brand 10w40 diesel oil?
Assuming you both mean the Kirkland 15W-40 HD diesel oil (not 10W-), it doesn't have high zinc levels. Should be no issue for cats. Pretty much the only oils that have enough zinc to harm catalysts are labeled "Racing" and have ZDDP levels >1500 ppm. Won't have that in a CK-4 rated oil.Yep, I put it in my super duty 7.3 with 346,000 miles on it. It seems to like it just fine. I would not use it on my OM648 E320CDI because zinc and cats don't get along.
M-1 15W-50 is good stuff for a Group III oil, just don't attempt extended drain intervals with it. @Jlaa / #JITOG.For my M119 cars, I've been using Mobil 1 15W50 since 2004 and my cars love it. I tried 0W40 or 5W40 once and it didn't seem as happy.
YUP! That is what I use in all my Mercedes engines, gas & diesel. Good stuff. I buy from Summit Racing or Jegs in 4-gallon cases, even better when they have a coupon of some sort off $xxx purchase. For a low-use car, 5kmi over several years is fine, and the UOA confirms it.somewhere somebody on this board (probably Gerry or GSXR) told me to use this stuff in my E500 at 5k mile oil intervals and Blackstone labs confirmed everything ok
Really, this should end with a full stop. Extended oil changes are for fleet managers, not enthusiastsJust don't attempt extended drain intervals
...and also people who don't want to spend their Saturdays changing oil that doesn't need to be changed. Er, I mean "doesn't need changed", as the kids today would say. There's nothing wrong with changing every 12 months or 3kmi, whichever comes first, but I have better things to do with my time.Really, this should end with a full stop. Extended oil changes are for fleet managers, not enthusiasts
I use a 10k interval on our daily-driver 1994 E420 which works out to about every 2.0-2.5 years. It uses less than 1 quart, I don't add oil between 10k changes, and the UOA comes back fine. Cars that consume more, yeah... wouldn't make sense!I'm pretty sure if I tried a 10,000 mile oil change on my Jaguar, there'd be no oil to drain.
The OM60x diesels have camshafts which directly contact the lifters, same as M119 and M104. High levels of ZDDP (~1500) are not required as on the M117. Rotella T6, being a diesel-specific oil, is fine. They claim the 15W-40 has MB 228.31 approval. In general just make sure you use a diesel-rated (Cx) oil for your MB diesel. Don't worry about ZDDP levels. For extended drains you will need to get UOA with soot levels, which generally are the limiting factor.At the risk of getting flamed, even though it is still a W124, I bow to the great 500E owners and beg your pardon if I ask on W124 Diesel engines like OM602 how this entire discussion applies? Is ZDDP a matter on those engines, or can I do my usual Rotella T6? Or other recommendations?
Yeah… lately on some of these cars I’ve been on 2 year intervals which is maybe 5k miles if I add them all up…I use a 10k interval on our daily-driver 1994 E420 which works out to about every 2.0-2.5 years. It uses less than 1 quart, I don't add oil between 10k changes, and the UOA comes back fine. Cars that consume more, yeah... wouldn't make sense!
FYI. Mobil, as of May 2022, has reformulated many of their Mobil-1 viscosities to conform to GF6A to combat turbocharger-induced low speed preignition.Re: OWNER: Ertech
Klink, thanks for the tip! I didnt realize M-1 had reduced the ZDDP levels in the 10W-40 formula, by 200ppm each, sometime in the past 2 years. Current Mobil spec sheet (Feb-2018) PDF attached plus screen shots. Older spec sheets available here. The M-1 15W-50 still retains politically incorrect levels of ZDDP, as does M-1 0W-40 FS (not to be confused with M-1 0W-40 ESP, or any other version of 0W-40). Remeber, all the Mobil-1 products in xW-40 or xW-50 viscosity are Group III synthetics, which is why they are cheap. If you change at 3k-5kmi, they are fine.
Red Line 10W-40 still has ZDDP levels in the 1000-1200 range based on multiple UOAs from my engines over the past few years, plus they use moly and some Group V (ester) base stocks, which makes me feel warm and fuzzy inside. Available at Jegs or Summit Racing for ~$48/gallon, free shipping over $99.
FWIW: The Mercedes dealer 5W-40 oil specd for the AMG M156 engine (with similar valvetrain design as the M119) has relatively low ZDDP levels, ~800 P, ~1000 Zn (based on UOA). The M119 valvetrain doesnt really need a super high ZDDP levels like the M117, but I still dont like low-ZDDP emissions-friendly oils.
On sale till this weekend… $8 off.Any try Costco’s Kirkland brand 10w40 diesel oil?
I'll have to get some as I use it in my 7.3 powestroke diesel. Then when I go 15,000 miles in it. I drain it and pour it into my MercedesOn sale till this weekend… $8 off.
Cheaper in the warehouse by $1 if one is close to you.
It is 15w-4” and not 10w as I had mistyped previously and gsxr corrected it.
Pretty sure that this is what I'm using on the 7.3 Powerstroke. I think I read somewhere that it's made by Warren Oil. I think that it's fine for older Mercedes with M117/M110 engines. On the M119, I've almost always used M1 15W50 and on the M113's, always M1 0W40. I tried 0W40 on the M119 once and it didnt sound as quite or as smooth.
Why diesel oil? is 5W40 ok for 115º weather?All the oils have been reformulated through the years.
In the mobil-1 lineup, I would use 5W40 synthetic diesel oil.
Michael
In the past, diesel oil generally had a better additive package, and/or higher amounts of ZDDP. This has been changing with the newer diesel oils which are designed for new, low-emission diesel engines. Some diesel oils may still have the "good" stuff, others may not. Lots of research required to figure this out, if you are concerned about it. That said... the M119 engine does not require high ZDDP levels, and if you are changing the oil at 3-5kmi intervals, don't lose sleep over it. This is a bigger concern if you are extending oil change intervals to 7-10kmi or beyond.Why diesel oil?
Technically, yes, 5W-40 is acceptable for high ambient temps per the factory viscosity chart. However in a very hot climate like that, I'd probably use a 15W-50 or 20W-50 synthetic. Those would also be ok at temps around freezing for year-round use.is 5W40 ok for 115º weather?
I never knew there was such a science to engine oil. I used RedLine in my diesel Peugeot. I've been using Lucas oil in the 500E and RR, it's pretty thick stuff. I made a few calls trying to find RedLine oil. Their website is out-of-stock and I couldn't find any oil anywhere in Scottsdale/PHX or the usual internet sites. I couldn't find the (good) oil filters either. So I didn't change the oil before I take it up the mountain. The temps here are still over 110º, was 114º today. Tell me a brand that's easier to find than RedLine. This is all new to me. I called Schumacher Mercedes and they suggested MobilOne, but I see it's not one of your favorites. I'll change the oil when I get back down the mountain.In the past, diesel oil generally had a better additive package, and/or higher amounts of ZDDP. This has been changing with the newer diesel oils which are designed for new, low-emission diesel engines. Some diesel oils may still have the "good" stuff, others may not. Lots of research required to figure this out, if you are concerned about it. That said... the M119 engine does not require high ZDDP levels, and if you are changing the oil at 3-5kmi intervals, don't lose sleep over it. This is a bigger concern if you are extending oil change intervals to 7-10kmi or beyond.
Red Line is usually pretty good about answering tech questions via phone or email. However, Red Line increased their prices substantially at the end of 2022. I would typically buy from Summit or Jegs as they would have a discount on orders over $200 or something like that, and Red Line never goes on sale. With the price jumping from ~$50/gal to ~$66/gal (~$12/qt to ~$16/qt)... I have a hard time recommending Red Line for daily-driver use, due to the cost. I still like Red Line for high performance / forced induction / racing applications, or if a $150 oil change in your budget.I never knew there was such a science to engine oil. I used RedLine in my diesel Peugeot. I've been using Lucas oil in the 500E and RR, it's pretty thick stuff. I made a few calls trying to find RedLine oil. Their website is out-of-stock and I couldn't find any oil anywhere in Scottsdale/PHX or the usual internet sites.
Hengst, Mann, Mahle, or Knecht are all acceptable OEM filters for the M119. However, the OE/dealer filter is reasonably priced from discount dealers. I buy a few at a time with other parts to get free shipping and just use the OE filter. Otherwise, any of those four OEM brands are fine. Currently $10/ea at Naperville (link), free shipping over $100 with code 500EPROMO.I couldn't find the (good) oil filters either.
Mobil-1 is a decent oil, just not on the same level as Red Line. My gripe with Mobil-1 is from 15+ years ago when they quietly cheapened the base stock without lowering the price. Not cool. However, it's a good-performing oil as long as you change it by around 5kmi. I use Mobil-1 in my daily driver / beater E420.So I didn't change the oil before I take it up the mountain. The temps here are still over 110º, was 114º today. Tell me a brand that's easier to find than RedLine. This is all new to me. I called Schumacher Mercedes and they suggested MobilOne, but I see it's not one of your favorites. I'll change the oil when I get back down the mountain.
Exactly my observation/thoughts... I still use it in R129 and Porsche (15w50 for both), but these get oil changes only x1 per year, so I feel that the expense is justified...However, Red Line increased their prices substantially at the end of 2022. I would typically buy from Summit or Jegs as they would have a discount on orders over $200 or something like that, and Red Line never goes on sale. With the price jumping from ~$50/gal to ~$66/gal (~$12/qt to ~$16/qt)... I have a hard time recommending Red Line for daily-driver use, due to the cost.
I just got tired of chasing good oils on sale, and been using Mobil-1 in the daily cars, and still do (5W40 is now in both W211 cars, Volvo and was in W202 until I sold it). Mobile-1 I used exclusively in W202 and I've had it most of it's life... When the valve covers were pulled of M112 to replace the gaskets, heads literally looked brand new (I've had the car for well over 100K miles, not even a stain), but religiously changed every 5k miles, and still do all the remaining cars.Mobil-1 is a decent oil, just not on the same level as Red Line. My gripe with Mobil-1 is from 15+ years ago when they quietly cheapened the base stock without lowering the price. Not cool. However, it's a good-performing oil as long as you change it by around 5kmi. I use Mobil-1 in my daily driver / beater E420.
