IMHO, this oil guy (though a serious dork) is infinitely more tolerable than Hoovy. Much like Uncle Kent, I’m happy to pay him with a YouBoob “watch”.
I can’t say that for Hoovy. I’ve never understood why a trust fund kid like Hoovy even needed a YouBoob channel to make more money. I guess it’s so he feels like he’s actually doing something productive with his life.
Getting close to that high mileage award...nice!For many years, my oil consumption with Motul 300V Power 5w-40 oil was a tad less than 1/2 quart every 5.5K miles. But about eight months ago, I switched to Motul 300V Competition 15w-50 oil and after 4K miles no oil has been consumed. However, the car is not being driven daily as before, so I need to wait and check at 6K miles. I always found that the oil pressure (although mine was well within the factory specs) was a tad low for my liking, especially when sitting in long traffic in the hot summer weather and when getting off the freeway in the hot weather. I started to notice that towards the ending of my track participation a few years ago. Long story short, the oil pressure is much better now, a 1/2 bar higher than before and in all weather conditions. The engine now has 168K miles on it and I’m sure the tolerances have increased a bit, so the 15w-50 oil will be used from now on.
I think you're going to be very very happy with the 15W-50 viscosity, particularly living in SoCal.
penngrade1.com
We run Brad Penn in everything that was designed mid 90's and earlier
Yes, it sounds indeed very expensive. I am assuming $250 is for a case of 12 quarts. IIRC you need about 8 quarts (1 quart = 0.95 liters), perhaps a bit less per oil and filter change. Anyway, what I am suggesting is that you hook up with two more guys who would like to have Brad Penn and order two cases, a total of 24 quarts. That would be $500 but your share would be 500/3=$167. 167 is much better than 250, just saying.Yes, I can order Brad Penn from Amazon US, but unfortunately it will cost me close to 250$, shipping is really expensive.
that means M119, right? you chose to run Brad Penn 20W50 in M119s over modern 5w40 oils? Just clarifying. Thanks
Older engines were designed for higher viscosity oil and typically have larger bearing clearances.
If you continually have a gas smell, and cannot locate any sign of a leak, check if you can put in 16 gallons (into the 18.5 gal tank) when the reserve light comes on. If it's much less... say 14 gallons or less... you might have a partially collapsed tank with hairline cracks causing the fuel smell. If the tank capacity is normal, keep looking for the leak.I smell a faint gas smell when I am in the trunk area, but I could not find definitive signs of leaks yet.
I'd stop using the Slick 50.I have a 94 E320/M104 Wagon with 209K that's nearing completion of a topend rebuild like what Gerry did with his 95 year in 2013. I live in Southern CA. What I've been using the last 100K miles is Castro high mileage 20/50 including a bottle of Slick 50. It was changed every 2500 miles but more frequently every 2K betw 150K to 209K. Any recommendations for change after this rebuild and reason why? TIA. -Steve
Background reading on slick50 .... I think archived from Usenet in the 90sI'd stop using the Slick 50.![]()
Thanks for the link, @Jlaa! I'll mirror that article on my site as well.Background reading on slick50 .... I think archived from Usenet in the 90s
I have said similar things for many years. I inherently have nothing against synthetic oils (and actually use RedLine synthetic in my E500, and RedLine synthetic gear oils in my G-wagen front/rear axle and transfer case). But if you have a mid to higher-mileage engine, and you suddenly change from using dino oil, which the engine is used to, to synthetic oil, you ARE going to have leaks develop. That's just how it is.Mike Akbar at Akbar Service in Upland always said: M104 and M103 engines will go 500,000+ miles if you 1. Change the oil every 2,500 miles and 2. Use Pennzoil 20W/50 ONLY. Every oil change.! That brand. That weight. Only. Every oil change.
When I asked him why, he said that these engines can’t handle synthetic oil and will eventually begin to spring leaks in odd places; the heavy oil leaves deposits inside the engine that bind to the sealed areas, like gaskets, I suppose, which kinda tightens up all the jointed areas and strengthens them over time. It’s part of the design.
Anyway, his point was that synthetic oil is actually designed to remove those micro-deposits placed there previously and slowly, that causes problems. Best thing these engines respond to is 20W/50 and always the same brand. In the 80s and 90s Pennzoil was used by all Mercedes-Benz dealers in N. America so the older cars are used to that brand’s formula and it’s a high quality product so he recommended I stay with the dealer brand of my car’s era. I took his advice when my car had 128K miles. The current owner has 311K on it and has maybe spent $3,000 on it since 2004. He did exactly what I told him when he bought it from me. I don’t think there’s any downside regardless...
Best of luck,
J
The statement "these engines can't handle synthetic oil" is completely, entirely, false.When I asked him why, he said that these engines can’t handle synthetic oil
I agree. These engines certainly CAN handle synthetic oil. I think he was inferring what you just said -- that older engines with original seals are very likely going to leak after switching to synthetic oil. If new seals are installed, there is no reason why things would leak if synthetic oil is used from the get-go after seal replacement.The statement "these engines can't handle synthetic oil" is completely, entirely, false.
More accurately, an old engine with old seals MAY develop leaks if switched from dino to synthetic.
If you are driving 5kmi in 3 months (!!), you can very likely move to 10k intervals. However I would get one oil analysis at 10k including TBN, just to confirm. High mileage in short time spans is the ideal scenario for extended drain intervals.
BTW, the oil level should normally be in the middle between MIN and MAX, I assume your photo had allowed the oil to move on the dipstick?
But if you or GSXR lived on the Canadian border? Would that change your thinking on 5W?^^^
The Gospel according to @DITOG.
I’m a big fan of 20W-50, 15W-50, 15W-40 and 10W-40 in my cars. M117, M104, M119.
NO 5W- or 0W-anything in my Benz engines.
Thanks Vookster for saving me a trip downstairs to my office at 0240 hours.
