1993 400E 196k miles.
Owned the car for almost 2 years, bought at 187k. It always had a 3-4 shift flare, even after a trans service with all OE parts and fluid. At 194k miles, I changed to Type F fluid at the recommendation of several on this forum. No change to shift quality with Type F. About 1500 miles later, it started shifting erratically only when warm. when cold, it shifts fine(except the 3-4 flare), but as it warms up, the shift quality degrades. When fully warm, it SLAMS 2nd gear, then immediately shifts again and flares the 2-3 shift, and then immediately shifts again, and flares the 3-4 shift. I have the lift off the gas for either flaring shift When this happens, I'll be in 4th gear at 20-25mph, good thing it has lots of torque. The transmission has always felt kinda clunky with downshifts, and feels worn overall, but even when warm, doesn't slip when in the gear, only when shifting. The modulator is not leaking, and adjusting it seems to be making a difference, but does not affect warm shift quality. I went back to OE fluid, but no change.
I am planning on a rebuild, or rebuilt exchange trans at some point, hopefully later than sooner.
I'm also an MB dealer tech, if that help with technical questions.
Thanks guys.
Ian R.
Thanks guys.
Ian R.
