yeah sometimes it happens tho like I don’t know how to explain but with it sometimes if they pedal is hard its like but seem like it doesn’t like to go up with the rpm unless floored, but it feels solid in power however almost like slow as in timing/response but when the pedal is freely it’s like the rpm rev higher but seems like the power isn’t there like it isn’t really pulling, but like let’s say I’m merging on to the hwy and I pressed the gas heavy, it feels like it takes forever to get going but sometimes I feel it pulls strong but still not getting no good mid ranger power but then after a bit of holding down the pedal I’ll start to pick up speed, I’ll have to do a pull and see what it doesIf the ASR light comes on and thats when the accelerator pedal does nothing for the first 1/2 of travel, that is classic limp mode. Search the forum for more details. Restarting the engine should cure / reset it temporarily. Odd thing is none of your codes seem to indicate limp mode. If the ASR light comes on and the accelerator pedal feels normal, thats different.
ive Checked the fuel pressure before and it all read good but it has been a long time Sence then,
  I took around of 100 pictures of the wiring alone when I was disassembling my 400E, and I'm still not sure if I will be able to put this car back together.
