Hi there, have a '95.
The transmission shifts hard sometimes in 2 scenarios: (note, this happens when trans is cold in the morning (I know about the cat warmup module that delays shifts) and it also happens after hours of driving and everything is hot.
1) When upshifting at low speeds with barely little throttle only on the 1-2 shift. Think of going around the parking lot at the store from a stop, and if I give it enough throttle to creep and it eventually winds up to shift into second, sometimes it snaps your heck and feels like a kick in the back when it hits second.
2) What makes it do it most of the time is when you've been doing like 50mph, and slow down to turn at a light or turn down a street and then get back into the throttle not just barely, but a little more spirited than that that would justify it to kick down one gear, that kick down is just as snappy and kicks in the back with the same clunk as in #1 above.
So basically it does it at slow speeds with little throttle upshift 1-2, and then does it when you're already at speed, and slowing down to take a turn and a little more throttle for it to kick down.
The other shifts are all fine, no matter the throttle input or speed or kickdown. Even the kickdown on the freeway (both kick down levels) don't bang like #1 above.
It has done this like three years and I'm finally getting around to resolving it. It also did it before I did new diff bushings and new carrier bushings and new trans bushings and has done it after.
If I tune down the vacuum modulator then I get the 2-3 flare and the #1 and #2 above weren't really improved.
I even tuned it using a gauge in the side port to the psi on the specs. Filter and fluid are also brand new. Turning down the modulator a lot doesn't really change that "bang" much, maybe 30% less?
150k miles on this trans that I know of.
Vacuum modulator holds vacuum and doesn't really leak down, if it does it is over minutes to do so.
Ideas?
Ideas?
