From my mechanic. Suggestions?
Ok, the old switch had corrosion on the pins, so seeing how it was old and not very expensive, it was an easy call to replace it. It did not fix the kickdown issue though. I checked for power at the solenoid with the switch depressed, and I have none, nor do I have power at the back of the switch. I believe the switch gets its power from the base module. All the fuses in the BM are fine, but I need an accurate wiring diagram to trace out the wiring from the switch to the BM. Can you see if anyone in the 500E group has that diagram? The only thing I have is a 500SL, 129 chassis diagram which is similar, but I need the right one to go in deeper.
