Well, I stopped by Alternators Unlimited and picked up a remanufactured "Alternator for a 2000 MB ML430".  It was inexpensive - only $160 + $40 core.  Not sure if I got ripped off or what I got is legit.  I can return it.....
Alternators Unlimited --- seems legit.  Its a small building and there's one guy (the owner since 1975) rebuilding everything himself.  Lots of mechanics go here as evidenced by the wall of cards.  The son is the one who does the sales and the one who helped me...... he doesn't seem ultra-technical like the dad.
This is what I got.  They had two of these that they rebuilt themselves but neither seem to have the Bosch-embossed black plastic cover.  They had one more remanned alternator for Mercedes that DID have the Bosch black plastic cover, but it was a 120amp model, not a 150amp model.
The sales-son indicated that they typically don't replace the case nor the diodes since, in his words, "Original diodes often cannot be beat".  That said, the alternator DID have a Bosch voltage regulator inside.  Taking off the back cover --- things
looked nice?  But I have no idea how to tell if this is a quality unit.  The brushes measure 10.67mm.
The sales-son ran it on the machine for me twice with two setting --- once w/ the ammeter at 40amp range, and once w/ the ammeter running at 80amp range at my insistence.
In this first run, he verified that the voltage spit out by the alternator was 14.53 volts.  He told me that the alternator spit out over 80amps (he said pegging the needle), and that's what he expected so that it meant the alternator was good.  I have no idea how fast the electric motor was running or what the size of the pulleys were, so I have no idea if this was supposed to simulate idle speed or what, but I should have asked.  Confusingly, I did not understand at all why the machine was set to "40 amp range" when Sales-Son pointed to the needle at 80+ amps.  He was really nice and friendly, but he said, "that's the way we test it - we set this super old machine to 40."
He ran the machine again with the amp range knob set to 80 amps and he said the alternator was spitting out 150amps (again doubling the number which I didn't understand?).  Maybe because the alternator spits out AC and not DC?
Anyways, for only $160 + $40 core, I was fairly pleased (especially as a Bosch branded Bosch reman alternator would run me at least $350-$385, shipped to my door) but I still wanted to double check, so I decided to take it to a local autoparts store to test the alternator.  OMG I had no idea this would be such an ordeal.  I called 4 each of Autozone, NAPA, and O'Reilly.  All the Autozones and NAPAs either said they don't bench test alternators anymore or that their machine was broken.  Only O'Reilly bench tests alternators around here, and apparently O'Reilly rolled out new bench-testing machines chain-wide that are made for KISS stupid operators.  The tester apologized to me profusely that the new machines don't give me an amps rating ---- it only gives me a PASS or FAIL.  We input in the year / make / model of the car into the computerized bench tester (where I suppose there is a database of criteria that the machine looks for) and the machines spits out PASS or FAIL.  This alternator PASSed, although I have no idea what that really means.
So what say you guys?  Keep or Return?
