were the lights working before? it's uncommon for the rotary switch to fail suddenly, especially if all the detents feel normal.Re-installed the headlights. Low and high beams don't work. New bulbs. Fuses look fine. I'm guessing rotary switch.
A small fuel leak, or theoretical air bubbles, is extremely unlikely to have caused the engine to shut off.Weird, after getting a push out of the driveway under the freeway where I was stranded, sitting around for 15 minutes waiting for the tow, Mr. Grey started right back up. Air bubbles in the fuel line because of the fuel leak? Car stopped after a steep downhill right hand turn.
The front one is a vestigial sensor, and connects to nothing - ignore it. This was deleted as of the facelift, for cost reduction, along with the 9-pin diagnostic port near the EZL.Thank you. I assume that the part number for the front is different from the one buried? I haven't researched part numbers yet.
Carlo,Anyone know if replacing the RDM bushings (I have new ones) is as simple as popping that top cover off without having to put the car on jack stands etc?
Read post #'s 56-61 at this thread. Klink explains how it works and why you need 2 wenches to loosen the jam nuts.I located the SLS lever. I don't understand why I need two (2) 10mm wrenches to loosen what I think needs to be loosened in order to raise the lever.
Measuring will define the specific height. Stock 036 is around 14.5" from fender lip to wheel center. Most people view this as "too high" and want to drop closer to 14.0", approximately.Car is super low.
Sweet! Make sure to replace the foam stop buffers at the same time (OE only)... ditto for the accordion dust boot if it's not in good nick. Check the strut mounts while you're in there.Stopped by the good folks at MB Classic to pick these up.
There should be plenty of photos on the forum showing Evos without spacers. They don't "poke" as much, but still look very good. Easiest search would be for E500 Limited models for sale in the classified section.Anyone run Evo wheels without spacers and can post pics? I noticed my front wheels have spacers and I wanted to run th without it- assuming bolt length works for both.
Ah thank you @gsxr !There should be plenty of photos on the forum showing Evos without spacers. They don't "poke" as much, but still look very good. Easiest search would be for E500 Limited models for sale in the classified section.
Bolts must be standard 40mm shank length. If your existing bolts screw into the spacer itself, they may be ok. If it's the type of spacer with holes only (no threads), your bolts may be too long.
The "correct" bolts for Evo wheels are the extended-head type with 75mm total length, but these are nearly impossible to locate. The 72mm total length bolts are more common and (slightly) easier to locate as they were used on most all late production 124's with standard 8-hole wheels. Short-head 65mm bolts don't look right with Evos, IMO. See photo below on an Evo wheel. All of these bolts have 40mm shank length, only the length of the extended head varied.
#32 are the 2 bolts which attach the strut to the front knuckle. I am not seeing these as NLA / Discontinued, just "Currently Unavailable" via online part websites, which is often code for "may need to order from Germany". The options are:
