FYI Exploring the Super MB Star M6+ Diagnostic System
Site Honcho
This thread is intended to be an in-depth exploration of the new generation of the Chinese-made "Super MB Star M6+" diagnostic systems that came into production in the late 2023 period, and began being sold in early 2024.
Introduction
As discussed in recent (December 2024) posts in the “Exploring the C3” thread, there is a relatively new generation of MB diagnostic system that has been created by the Chinese, called the "Super Star M6+." This new diagnostic system was introduced around the end of 2023, or in early 2024.
I recently purchased and took delivery of one of these Super Star M6+ systems, and will use this thread to explore it in depth as I learn it and get to know it -- both for my 1994 E500 and for my more modern 2007 W211 E63 AMG.
Background and Context
The Chinese Super Star M6+ system is the successor to the Star C3 and C4 systems that have been sold over the past 10-15 years. Available from about the 2008 or 2009 time period, the Star C3 system was the original "hacked" version of the MB Star C3 ("Compact version 3") DAS system, and was followed sometime around 2015 or so with the Star C4 system. Literally the Chinese made direct physical clones/copies of the factory MB "Star" system multiplexer, with questionable but functional internal multiplexer electronics, and utilized "hacked" versions of the MB DAS, Xentry, WIS, EPC and other related software loaded onto hard drives and later directly onto serial-port-equipped laptop computers.
Early C3 systems ran in a Windows XP-based virtual machine running on top of Windows XP. Later C3 versions and the Star C4 ran directly on Windows XP, eliminating the virtual machine and its significant performance penalty. They contained all of the key MB software that was needed, including HHT-Win, DAS, Xentry, StarFinder, MediaDB, StarUtilities, and so forth.
MB first introduced the Star C4 system in early 2012. The C4's multiplexer was called "SDConnect." The Star C4 was a modest improvement over the C3, mainly adding a wireless interface between the multiplexer and the host computer (also retaining wired connectivity if desired), eliminating at least SOME of the cumbersome cabling that tended to get in the way when out in the shop working underhood.
Both the C3 and C4 systems had their quirks in many respects, particularly in regard to the reliability of connections, component quality, cabling quality, and software compatibility. The C3 and C4 system generally required an old-school Windows laptop (running Windows XP) that had an old-school SERIAL port -- something that many many computers haven't had for many many years (generally replaced by USB). And the Chinese-made multiplexers often had a limited life, and were fairly clunky and large. For the most part, these systems worked, but sometimes required some work to get them to interface with cars correctly. Furthermore, the HHT-Win emulation software was sometimes eliminated from some Star C4 systems in recent years, limiting the usefulness of the system for 1990s and very early 2000s cars that performed diagnostics and live data provision through the 38-pin round connector.
The C3 systems were gradually squeezed out of production by the C4, and have been largely unavailable for the past 2-3 years (except as used systems). If you search enough, you can find a few vendors who are still selling new C3 systems. We have linked below to one such vendor. The C4 systems are generally applicable for MB models from 1996 through 2022, with a few chassis exceptions in the latter years. The C4 generally is more reliable than the C3, supports more languages, supports more vehicles, and more protocols.
More recently, MB has introduced the Star C5 and C6 systems, which are designed to handle more modern cars. The C5 (also called "SDConnect" by MB) is functionally very similar to the C4, but its multiplexer design is much more robust and reliable and less prone to overheating. However, the C4 remains in very very broad use by folks like us, independent shops, and so forth. However, like the C3 before it, it is disappearing and becoming less available on the market.
The Chinese "clone" C5 systems that are available, are literally just C4 multiplexer innards that are put into a "cloned" MB C5 outer multiplexer case, and are functionally no different than a C4.
The official MB Star C6 systems multiplexer is common called "Xentry Diagnosis VCI" by the company. You can see photos below of all generations of the official MB multiplexers, from the C3 through the C6.
Reference photos of MB Star multiplexers:
Star C3 multiplexer:
Star C4 ("SDConnect") multiplexer:
Star C5 ("SDConnect") multiplexer:
Star C6 multiplexer (aka "Xentry Diagnosis VCI"):
The Next Generation
This brings us to the advent of the Super Star M6+ systems, which have been introduced starting in very late 2023, and are well into replacing the Star C4 systems that have typically been sold by most Chinese vendors.
The Super Star M6+ system is a complete redesign and refactoring of the older-generation C3 and C4 systems. For the first time, the Chinese have not simply produced a clumsily aped / cloned external and somewhat functionally equivalent version of the MB Star Compact internals. They have actually engineered their own proprietary multiplexer, and taken it in some interesting new directions.
Example of a Chinese-made Super MB Star M6+ multiplexer:
The M6+ consists of a significantly more compact and fully self-contained multiplexer that is literally a full computer in and of itself. It has a short "bootup" period, has an internal cooling fan, and is both Ethernet and WiFi-capable (and offering users the option of connecting to the host laptop/tablet via either type of connection).
The M6+ multiplexer has a large serial connector on one side that connects via the provided diagnostic cables (typically an OBD-II or for E500E owners, the 38-pin connector) to the car's diagnostic port. If you opt to connect the M6+ multiplexer to the host computer via wired Ethernet, this is done with a regular USB cable (such as is used to connect a printer to a desktop or laptop computer). This is MUCH better than the old serial connector of the Star C3 systems (although the Chinese Star C4 and C5 systems also offered wireless connection to the host computer, with varying levels of connection strength depending on the host laptop used).
M6+ buyers have the option to run the MB software associated with the M6+ either on a Windows 10-based laptop computer, or a Windows 10-based tablet computer. Because only a USB connection is needed (or WiFi), there are plethora of computers that can work for this. However, ChinaCarDiags.com offers laptop or tablet that come pre-configured with the MB software.
Here is a link to CCD's web page that shows all of their M6+ based systems:
Here are direct links to several "typical" M6+ based systems that are currently for sale by ChinaCarDiags.com:
Note that there are LOTS of other vendors selling identical or close variants of these M6+ systems on various web sites, including AliExpress.com, eBay, and their own web sites. Buyer beware when purchasing these -- do your homework and only work with sites and/or vendors that are known-good and provide a refund / resolution process. I was very happy with ChinaCarDiags.com and was able to talk easily and as needed with "Seven" there via WhatsApp.
Separately, you can ALSO purchase a Chinese "clone" of the official MB C6 "VCI" multiplexer (by itself, or together with laptop, tablet, or software). One vendor selling these "Clone C6" systems, can be found here:
:update:
This same vendor does, in fact, still sell C3 systems (as well as C4 and C5). If you want a C3 system, you can find it at the following link:
Comparison Table of MB Diagonstic Systems
As you can see from the above table, the newest-generation diagnostic systems from MB do not support older cars. Thus, as an E500E or 400E420 owner, it is probably best to stick with a C3, C4 or Chinese-designed M6+ system (Not the C5 or C6 systems from MB or equivalent Chinese clones, just to be safe). Although, the chart does say that C5 systems do support the older cars. My recommendation is to use a C3 or C4 or M6+ multiplexer with HHT-Win software, to be safe.
The Super Star M6+ systems are the first time that the Chinese have materially departed from directly "cloning" (particularly externally / cosmetically) the MB multiplexers, and have struck out on their own with a multiplexer of their own design, yet of similar or even more functionality than the "real" MB multiplexers. By more functionality, I mean that the Chinese M6+ multiplexers are fully capable of and configurable for handling BMW diagnostics, the DoIP protocol (which the Star C4 and C5 systems could also handle), in addition to MB diagnostics.
So, that should provide an overview of the diagnostic computer situation, as well as current options, and such. Next posts will get more into connecting and using the M6+ system.
Super MB Star M6+ Diagram
Here is a diagram of the controls and indicators on the Super Star M6+ multiplexer:
The following post shows an unboxing of the Super MB Pro M6+ system as received from ChinaCarDiags.
Here are unboxing photos of the Super Star M6+ system:
Opening the box with a razor blade:
Box flaps opened:
Removing the computer case on top of the box, reveals some cables and a cardboard box inside:
Removing accessories included in the box:
  1. A/C adapter for tablet
  2. IBM USB mouse (not sure if I will use this....)
  3. International travel adapter (not sure I will use this....)
View of the outside of the box containing the Super Star M6+ multiplexer:
Opening the multiplexer cardboard box shows a hard, blow-molded plastic case:
Opening the plastic case reveals a manila envelope and various cables:
Removing the Super Star M6+ multiplexer from the manila envelope:
Physical views of the Super Star M6+ multiplexer:
Unpacking the Panasonic Toughpad tablet from the computer case:
Close-up physical views of the Panasonic Toughpad tablet:
Pressing the power button of the Toughpad tablet begins its boot-up process. After a few minutes, it results in the screen as you can see below:
The following photos show shots of the screen of the Panasonic Toughpad tablet that show the software that comes loaded on the system:
Close-up views of the software load included on the Toughpad tablet's SSD:
And here are some sample screen shots of the Super Star M6+ system, where I was exploring the system and its ability to interface with my 2007 E63 AMG (W211).
I have not yet tried the system to interface with my E500, but will do this in the future. The Super Star M6+ system DOES come with a 38-pin interface cable, as well as the HHT-Win software installed on the tablet/laptop.
Below is an instance of HHT-Win that was handed off from the DAS software:
The first and second posts in this thread have been significantly updated. This post is a net-new post.
Here is a general inventory of software that is included in the ChinaCarDiags.com Super MB Star M6+ system (tablet or laptop), as of December 2024.
Most owners of W124 vehicles will primarily run the Xentry software (which automatically transfers over to HHT-Win when a 38-pin connector is sensed), the WIS-ASRA, EPC, StarFinder, and perhaps MediaDb software.
Owners of newer cars (210 and up, particularly model year 2000 and newer) will likely use the same as above, except will use Xentry or DAS depending on your car's model year. HHT will not be invoked for cars after model year 1999.
Software Module NameDescriptionNotesScreen Shot
HHT-Win (Hand-Held Tester Windows)Emulates Hand-Held Tester diagnostics for carsGenerally from model year 1980 through ~1999. For cars with either 16-pin or 38-pin diagnostic connectors.HHT-Win.jpg
HHT-Win StopForces HHT-Win to stop execution in the event that you can't exit the program
HHT LanguagesNon-German language files for HHT software
DAS (Diagnostic Assistance System)Diagnostic software for MB vehicles with OBD-2 connectors. Used for cars post-38-pin connector.Generally from model year 2000 through 2009. Automatically switches off with DAS and HHT depending on the model year of the vehicle.
Xentry DiagnosticsDiagnostic software for MB vehicles with OBD-2 connectors.Generally from model year 2010 through present. Automatically switches off with DAS and HHT depending on the model year of the vehicle.Xentry3.jpg
Xentry Diagnostics AKTAutomatic quick test software for cars using Xentry DiagnosticsGenerally from model year 2010 through present.
Xentry Diagnostics SimXentry simulation software for training and reference purposesGood way to learn your way around the Xentry system (if you have a 2010 or newer MB)
Diagnosis StopForces Xentry to stop execution in the event that you can't exit the program
EPC 2018 (Electronic Parts Catalog)Factory parts diagram and part number/description referenceThis is a legacy parts catalog. MB switched over to the ISPPI system as of early August, 2018.EPC.jpg
WIS-ASRAProvides full repair documentation and procedures. ASRA is an electronic catalog of work units and flat rates, work tests, notes and graphics relating to vehicle partsWIS.jpg
StarFinder 2024Part location finder reference for all chassis starting with W210 and R129 and newer
StarFinder 2016Part location finder reference for chassis from 2016-presentStarFinder.jpg
MediaDbReference library of videos and PDF repair and maintenance lessons for various vehicles
VCI ManagerAdministration and management software for the MB C6 VCINot relevant to Super MB Star M6+ systems.
XEN-CBFXentry tool for working with Mercedes CBF files for programming ECUs, etc.CBF = Caesar Binary File. FOR ADVANCED USERS ONLY
DAS-CBFDAS tool for working with Mercedes CBF files for programming ECUs, etc.CBF = Caesar Binary File. FOR ADVANCED USERS ONLY
FlashWareCollection of all software used to flash/update MB computer modulesUsed in conunction with Vendiamo, Monaco and other engineering-level tools. FOR ADVANCED USERS ONLY
DTS v9Engineering-level coding license manager for Mercedes Xentry and DTS9 flashing and programmingUsed in conjunction with the ZenZefi module below. For the very newest DoIP-based MB chassis vehicles. FOR ADVANCED USERS ONLY
DTS MonacoEngineering-level software to diagnose, test, and engineer vehiclesReplaces Vendiamo for newer cars. FOR ADVANCED/TRAINED USERS ONLYMonaco.jpg
VendiamoEngineering-level diagnostic and development softwareOnly used with older cars. FOR ADVANCED/TRAINED USERS ONLYVendiamo.jpg
MB SeedKeyEngineering-level software to unlock MB controllers in different levels to get access to critical diagnostic procedures and functionsFOR ADVANCED/TRAINED USERS ONLY
ZenZefi-UIA tool that allows the management of user-specific certificates for the very newest MB chassis vehicles using the DoIP protocolGives access to functions like Xentry Diagnosis and DTS9 programming on W223, W206, W213, W167, W254, W197, W293 DOIP vehicles. Automatically loads the ZenZefi license onto Xentry, allowing diagnosis and flashing/programming on all DOIP-based cars. FOR ADVANCED USERS ONLY.
Hi Pierre,
Yes, the Super M6+ that I purchased has HHT-Win and a 38-pin cable included with the unit.
You should be able to see the icon for HHT-Win in the screen shots that I provided.
I cannot speak for every vendor’s system that is on the market, but I can confirm that the one I purchased does, indeed, accommodate cars with 38-pin connectors.
The unit you linked to above shows that it has BMW capability. If you have no need to test a BMW, then I recommend purchasing the equivalent unit without BMW, for a savings of about $100. Also, if you contact this vendor directly via WhatsApp, you can request a cheaper price and they will give it to you.
Hi Pierre,
Thanks Gerry, I did see the screen shots but wanted to be 100%.
I cannot find an alternative without BMW capability (which you are correct, I do not require) - the next cheapest I can see is this one:
Which is just over $100 less but has BMW capability and a Lenovo laptop instead of a Panasonic tablet (which appeals to me).
I have Seven's number and will make contact via WhatsApp.
Seven will help you. He will get you exactly what you need and will discount the price for you.
I got the tablet version WITHOUT the BMW capability, and a discount on top of that.
All the options I was offered (SSD, Laptop or Tablet) included BMW capability but I got this one for $750:
Happy Valentines day to me :hearts:
I think that is the same one I got, yes. You will be happy with it. Has worked just fine with my W211. Honestly I haven't tried the HHT-Win yet. It's just been way too bloody cold over the past couple of months....
A final question before I wait patiently for mine to arrive - what was the overall condition and battery life of the tablet you received?
Thanks.
Tablet was essentially new. Zero blemishes or other marks. Maybe an etch or two on the screen, but nothing bad or egregious. Only visible with close inspection.
Battery life? At least 4 hours I’d say. I’ve never used it for more than an hour at a time, but it was like 80-85% at that time.
what was the ... battery life of the tablet you received?
Just an FYI -- I used the tablet, fully charged, last Sunday for a full hour in my car. I then set it aside in my home office, and didn't touch it until today (Saturday night). So, it was sitting in suspended ("sleep") mode for about a week. Battery power when I just turned it back on is 64%.
If I had to estimate, I'd bet the battery power went down 10-15% over the course of the week, sitting in my office. I'd say the battery power was probably around 80-85% when I finished using the tablet on Sunday.
Mine has arrived, 12 days total since ordering from China to the UK and no import duties so that is a blessing.
My tablet is also in near new condition with basically no sign of use. It is charging up and will be ready for action tomorrow... time permitting.
I do have a quick few questions Gerry:
1) There is a very small instruction booklet for the Multiplexer - is this all I need to follow?
2) Presumably based on the above, I need to connect the tablet to my WiFi - is this correct?
3) Is the power supply provided for the Multiplexer when in use and the tablet needs to run off the battery or another power supply? If so, I will knock up a PSU which can run both simultaneously.
Many thanks.
Hi Pierre,
I don't remember there being an instruction booklet with mine. It's pretty self-explanatory, honestly.
I connected my tablet to my WiFi so that I could print documents. However, it's up to you.
You have the option to connect your tablet to the multiplexer via a cable (supplied), or via wireless connection (no cable needed). I opted for the cable. There are rudimentary instructions on the ChinaCarDiags web site about how to connect things up, and they worked well enough for me.
The multiplexer does not require a power supply. For my 2007 E63, it gets power from the OBD2 port. For the E500E (38-pin connector), it should get power from the car via that connector, just like the STAR C3.
The tablet runs off its own battery (or you can plug it in while it's running if you have an extension cord, but as mentioned it should run for hours on a full battery charge.
Hi Pierre,
Thanks, I'll scan or likely photograph the booklet I got and post it in this thread for others.
I didn't consider the car powering the Mux, it has been a very long day so apologies for asking a stupid question.
I'll also check the website for the guidance you mention.
Thanks again.
Many thanks.
Any initial impressions, observations, experiences, comments and anecdotes as to your new system? Interested to hear how it has been for you.
How bizarre that you asked…I was considering an update.
My multiplexer was DOA and wouldn’t connect by USB or WiFi. I sent photos to Seven and a remote TeamViewer session to fix was attempted.
I have returned my complete setup to a UK address in Manchester (Seven refunded the postal cost which was ~$25 due to the value) and a replacement has been despatched and should arrive soon I hope.
Customer service has been good so far and I’ll be sure to post an update when I get the replacement and have feedback to share.
After reading this thread I have one question: you two work on all kinds but for me, well I'm most likely never going to own anything new(ish) again if I am going to do the work. I like the M119 engines. So what was written earlier about C3 and C4 and considering all you have stated here, is it your advice that a person like me as stated is probably better buying one of these newer M+ systems because they are going to be better than the C3/C4 and doing a job of a C3/C4? Hope I'm making sense here.
Arguably, the actual bit you are using on the older 38 pin cars is HHT-WIN which is present on all types of MB Chinese SDS clones (make sure you specifically ask the seller as it isn’t a certainty) so you would be getting an almost identical user experience regardless of the hardware you use to interrogate your car.
Do you really think you won’t ever own an MB made after say 2013?
I don't know (shrug). I love what I have: 3 107s, 2 good 126 cars, the '95 S420 and my '91 500SL (love). I've given 2 of the 107's to my kids and will probably only hold a couple long term. I love the newer cars, don't get me wrong, but I had an AMG 209 and hated the driver controls and the cost to fix them- and the numerous fixes. I am to be going older, not newer, and feeling as faded as my old blue jeans.
"(make sure you specifically ask the seller as it isn’t a certainty)": will do!
There are issues with some clone C3 MUX's not working with the EZL, and separate issues with C4 cables missing most of the wires inside. Both systems are a gamble if buying new, and then you also need to verify the software package includes HHT-Win support.
The M6+ setup linked above works with the EZL, has a fully populated 38-wire cable, and HHT-Win support. $700 ain't cheap, but it works.
Bottom line, there are too many risks buying a new C3/C4. Buying a used C3/C4 kit which the seller has confirmed 100% works correctly with all LH-SFI systems including live data from the EZL, would be fine.
As R129UK said, the HHT-Win interface will be the same on all of them, only the hardware is different.
I too would recommend buying one of the new M6+ systems over the old C3/C4 systems, for the above reasons.
I actually have two different working C3 laptops and multiplexers that I'm going to basially throw in the trash, now that the M6+ system I have with tablet and better quality multiplexer is working so well.
And ..... I have a line on a NEW system (Windows 10 tablet based, or could use laptop) that literally can be had for well under $150. More on this soon. I will post a different thread.
Gerry, those older systems are still worth a few $$$, couldn't they be sold or even gifted assuming they are working rather than just dumped?
That is praise indeed, really looking forward to getting my replacement kit.
Wow, sounds interesting but can't fathom how the car might connect to the tablet / laptop so keen to see what you have to say about this new development :pc1:
I'd sell one of them. The older one (which is more than a decade old now) is certainly viable and usable, but it is running inside of a VM on the laptop, so it is EXCEEDINGLY slow (say 10 minutes) to fully boot up and get running.
The newer of the two is certainly 100% usable, and I'd probably be happy to let it go (laptop with software, C3 multiplexer, and cables) for $150. I have used it quite a bit and it is 100% workable with no issues.
Great thread- watching with interest. I have C3 and C4 systems which were rebuilt by Yuri to include high quality chips to original Daimler spec. (Member E500Star)
Regarding the C5 mux - I believe this was purely China design and no MB dealer has used or Daimler has ever made one of these.
I would assume the super M6 mux is the same - purely China invention. Does anyone know what mux MB dealerships are using at present(?)
I looked back through messages I had with Yuri. This is the only part we mentioned C5 muxes-
Sort of sounds like Diamler may have produced a C5 mux but he said to never buy it and stick with an original C4 Mux. (But not 100% on this - would be good if someone working in a dealer can advise what they use)
I think you are correct, as far as I was able to ascertain, the C5 is essentially just the C4's guts inside a different enclosure.
MB did produce a STAR C5 unit, and it was used with vehicles through the 2020 model year. However, most all shops and dealerships either used the C4 or skipped the C5 and went to the C6,
A C5 interface unit is indeed basically just a re-packaged C4 unit, with not a ton of differences.
There is no real compelling reason to use a C5 over and above a C4.
Okay- I get it. My weekday brain fog clears enough for me to see the wisdom you three are iterating= BUY THE DAMN M6+ UNA and quit being a numbskull about it! Will do.
Guru- I get your point as well as you are part of the above aforementioned "three". Even if I don't see myself in anything newer it is still the best possible option... because there are no other options.
Now to see if they are still available. #tariffs
AND NOW I SEE Gerry has a C3 he'd sell...
A friend of mine has a 600SL with a 38 pin port and he had taken it to several independent MB specialists and nothing had been able to connect to the car except my China clone C5…
Going back in my memory here (very dangerous territory there) the C3 and C4 require a separate dedicated/ stond only... and a very specific one as well, correct?
Yeah... the MB "specialists" are using the wrong diagnostic tools!!
:smack:
This discussion inspired me to hunt out my old Yuri rebuilt C3 Mux. It and its Dell laptop haven't been used for 3 or 4 years.
The laptop was dead but took a charge OK and when it fired up the DAS license had expired. I set the date back on the laptop and its licence worked again.
Connected it to my S600 and all good - still working great. I also have a Yuri built C4 mux and Toughbook which sees more use but I want to keep the C3 working well as it plays nice on the older cars too for sure, haven't tried the C4 on my 500E etc from memory.
F***! My recovery day has been marred with what I think is a stomach virus! "STOND"! LMAO! Suppo2b "stand alone" ! WT...
Apologies!
This is what you need:
1 - Laptop or Tablet etc. which runs the diagnostic software
2 - Multiplexer (aka MUX) - this is what allows the car to talk to the laptop (C3, C4 etc.)
3 - Network cable which connects the multiplexer to the laptop
4 - Diagnostic cable(s) - this connects the car to the multiplexer - there are various cables depending on the car type. The cable above is a 16 pin OBD cable which won't work with an E500E but most systems will include a 38 pin cable - MAKE SURE ANY SYSTEM YOU BUY HAS A FULLY POPULATED 38 PIN CABLE INCLUDED some cables are not and might not read all modules on the car.
gerryvz: I am new as a member of this board, would love to buy the 'newer of the two' if still available.
As I moved to retirement I took an interest in early aught MB's. Now have 5. '00 CLK320 (32k), '01 ML320 Designo, '01 ML320 Sport, '04 C230 Sport Coupe, 04 CLK320 (72k). I do all my own work, using StarTEK and my Fluke 902. And an older CLaunch. Including an engine swap on my MLSport.
Would love to 'stick my toes' into the Star Diagnostic universe. If still available.
@gerryvz https://www.500eboard.co/forums/members/gerryvz.1/
May have missed correctly inserting the member link for the above post.
You can tag someone here just by using the "at" sign in front of their handle.
Another member has reached out on this unit, and I committed to sell it to him.
The older unit is very slow, I don't think I would sell it to anyone. It works and the multiplexer and cables work, it's just that the laptop it is running on is ancient and honestly not worth the time and effort.
Hopefully you have seen this thread (linked below) that I am putting together. I should be finishing it up in the next couple of days with specific information. It should give you an EXCELLENT STAR/DAS capability for very very cheap. This would only apply to cars using OBD2 connectors, though.
Thank you for the reply. Will keep an eye out for your "System on A Budget" updates.
Meanwhile, If later you change your mind on the "older", let me know.
All of this with the MB's is and has been a learning curve for me as I bought first the Designo in 2015, then the Sport, then the rest.
I tinker a lot, Sometimes just to learn the basics. Was a Chinook 'repairman' (Army lingo) for a while in my early years.
Most likely, I will jump on the M6+, but later. I noted recommendations for it are in other places as well.
It is OK to 'invest' when one can be sure it works. That has been my hesitation on the 'clone' units.
