Hi everyone, hope you all having a great day, there is an opportunity to make a small batch of sway bars for the W124 chassis, specifically the sway bar from the V8 models. Why the V8 model bar design you ask, is because the V8 model sway bar can fit non V8 model but the non V8 model sway bar can’t fit on V8 model, so instead making 2 separate designs its easier and cheaper to make the design that fits all. The design that it was picked is the RennTech sway bar, that is 32MM thick all the way through and taper down to 22. Now, my question to all of you who might be interested is, what thickness would you consider be best and optimal?
- 30MM all the way through and then taper down to 22MM
or
- 32MM all the way through and taper down to 22MM
the rear will be sized accordingly to the front
- 30MM and 20MM
- 32MM and 22MM
Any suggestions on colors are welcomed.
Thank you all, will be waiting on comments.
or
- 30MM and 20MM
- 32MM and 22MM
