There was no ASR used on the W463 chassis. It would be 100% incompatible with the full-time four-wheel-drive nature of the vehicle.  Separately, though, it is possible to switch OFF the ABS capability, using a dashboard switch.  A "yellow triangle" in the middle of the speedometer gauge lights up when ABS is de-activated manually, and looks identical to the "yellow triangle" in the middle of the E500E speedo, indicating that ASR has been activated (or is faulty).
For the G320, the location of the ETA ifself, is on the driver's side of the engine block/head, under the intake system.  The "crossover" black pipe across the valve cover goes down INTO the ETA.
Here is a photograph of the ETA, removed from the intake manifold on the G320, but generally in the place where it resides:
The G-wagen, as far as I know, only has a few computers.
I am not aware of the G320 having an E-GAS or T/LLR module -- those are specific to the LH injection systems.  Looking through the official MB electrical wiring diagrams and component listings for the G320 confirms this.  My experience with the M104.992 in the W124, also confirms that there is no E-GAS or T/LLR module for the
[GVZ EDIT:  non-ASR] E320 models -- this functionality is controlled via the HFM computer, which integrates fuel, ignition and intake control functionality.
For the W463/G320:
The ECU (HFM computer), an ABS computer, and a cruise control computer are the primary computers.  Also an airbag sensor/control module, and an IRCL control module for the DAS system.
- The HFM computer is located behind/below the glove box on the passenger side.
- There is also a cruise control computer located behind/below the glove box on the passenger side.
- The ABS computer is located behind/below the glove box on the passenger side.
- The infrared remote (IRCL/DAS) control module is located in the glove box area.
I hope this helps.
