Hi friends,today i failed emission test on my 96 cl500!
I discovered that the engine runs smoothly as silk at times, but occasionally starts misfiring when hot! There’s a strong smell of a rich mixture coming from the exhaust!
The CO level was borderline, but the HC was very high! And the idle speed fluctuates occasionally!
I installed new Bosch spark plugs but set the gap to 0.8! Also fitted new ignition coils and coil boots! That was values:
I’ve ordered new Beru 14F-8DU4 spark plugs and will set the gap to 1 mm. I read online that Bosch spark plugs aren't competitive anymore since production moved to India.
Tomorrow, I’ll check the MAF readings using a computer.
What else should I look at? Most of the PCV hoses are new, and the remaining old ones are still soft and in good condition.
